390 coolant leak through block
Hi,
I just pulled my 390 engine to try and track down a coolant leak coming from the rear of the block. I was hoping it was a frost plug, but once I got it all apart it appeared to be leaking through the block wall somehow...after cleaning it up a bit it seems like there is a small round plug of some sort (approx 1/4") on the drivers side about half way up the engine...does anyone know what this is? or how this leak can be stopped?
Here are some pictures I took of the location of the leak...it's circled in yellow
Thank you!!
Thank you!!
While not very common it is a known issue with some FE blocks, read Dave Shoe's posts in the following threads...
332-428 Ford FE Engine Forum
Andy's Beast
10-31-2014 03:01 PM
