Old Jun 3, 2012 | 11:21 PM
1972RedNeck's Avatar
1972RedNeck
361/391
I have read that 361 and 391 FT's had the same bore castings as 428's. Is this true? How would I tell if I were to go look at one?
Old Jun 3, 2012 | 11:35 PM
85e150's Avatar
85e150
They have a 4.05 bore, are you thinking they will be thick enough to bore out to 4.13? If so, I think you will find it's a "maybe", depending on the particular block you find.
Try F600s and up, mostly up.
Old Jun 3, 2012 | 11:55 PM
1972RedNeck
I have read that they can go to 4.13 and then be bored as far as a 428 can be bored. But I may have been dreaming.
Old Jun 3, 2012 | 11:56 PM
1972RedNeck
Isn't there a drill bit test of some sort you can do on a 428? Would that work on a 391?
Old Jun 4, 2012 | 12:49 AM
85e150's Avatar
85e150
Drill bit test:
Cylinder Block | Mustang 428 Cobra Jet Registry
The pertinent passage:
"Measuring the gap between cylinders using a drill bit is the easiest way to determine whether your block is capable of supporting 428-sized cylinders. It is presently thought that if the shank of a 15/64" drill bit will NOT fit between the cylinders at any reachable spot in the six core holes, the cylinder will likely handle a 428 bore, core shift permitting....."
More discussion:
332-428 Ford FE Engine Forum: Cylinder wall thickness drill bit test interesting.....-----
and again:
332-428 Ford FE Engine Forum: 391 FT block to a 427 bore sonic #'s look good
The way to big cubes is the stroker way. Better to have a 4.080 bore with strong walls and a long stroke than paper thin walls with any stroke.
Old Jun 4, 2012 | 05:40 AM
gpence's Avatar
gpence
I've heard the FT motor's mite have a steel crank in them? I've never really looked into this but figured it was worth asking since I'm brainstorming my next "UP GRADE" build for my 390
Old Jun 4, 2012 | 07:06 AM
baddad457's Avatar
baddad457
The 351/391's did, but the 359/389 did not. Same engine family, different cranks. And forget about using the steel crank, for the cost to prep it to use in a HP application, you can buy a stroker crank and make far more power. Cast FE cranks were never noted for breaking, there's no need for a steel crank for 99% of applications in an FE
Old Jun 4, 2012 | 11:55 AM
gpence's Avatar
gpence
fair enough figured it was worth throwing out their.
Old Jun 14, 2012 | 10:28 AM
1972RedNeck
I have also read that FT's were externally balanced. Would an FT flywheel work on a 428 crank?
1974f250
Feb 22, 2009 05:49 AM
1985 Ford F-150
Jul 15, 2008 07:15 PM
Ron R
Nov 27, 2006 08:03 AM
sled_man4ever
15
Oct 17, 2004 11:28 PM
67 428 Fairlane Ranchero
13
Jan 14, 2003 10:43 AM
