Alternator Bracket
Old Jun 11, 2012 | 07:50 PM
mitchell390's Avatar
mitchell390
Alternator Bracket
well i posted this a while back and was told to talk to my local junkyard and i have but there computer says the dotn have any and they will not let me go look for my self or send one of there employees to go try and locate me one so i was just wondering if anyone would know the part number i have the adjustment arm i just need the alternator bracket adjustment arm part # is D3AE-10145-DA
thanks
~bryce
Old Jun 11, 2012 | 08:30 PM
mark a.'s Avatar
mark a.
What motor ?
Old Jun 11, 2012 | 09:19 PM
mitchell390
Oh shoot didnt realize i forgot to put it in the first post its a 400.
i bought another 400 motor thinking it would be the same alternator bracket but it was not so i figure there is 2 diffrent styles?
Old Jun 12, 2012 | 11:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mitchell390
well i posted this a while back and was told to talk to my local junkyard and i have but there computer says the dotn have any and they will not let me go look for my self or send one of there employees to go try and locate me one so i was just wondering if anyone would know the part number i have the adjustment arm i just need the alternator bracket adjustment arm ID engineering # is D3AE-10145-DA
Your question is confusing. Do you want the alternator adjustment arm you posted the ID number from? Or the alternator mounting bracket (a round spacer is also required)?
Marked with ID number: D3AE-10145-DA = Ford part number: D3AZ-10145-D .. Alternator Adjustment Arm / Obsolete / 1 available NOS
Applications: 1973/75 LTD 400 w/o A/C / 1976/78 LTD 351M/400 w/o A/C // 1977/79 F100/350 351M/400 with/without A/C / 1978/79 Bronco 351M/400 with/without A/C.
D4AZ-10156-B .. Alternator Mounting Bracket / Obsolete / 2 available NOS
Same applications as above.
D1AZ-8A652-A .. Spacer-Use w/Alternator Mounting Bracket / Obsolete / 60 Available NOS
This round aluminum spacer is about 4" long, is split w/a hole thru it for the mounting bolt. It must be cut to fit. Used on all V8 engines from 1971 thru 1979 and etc.
Old Jun 12, 2012 | 12:54 PM
lostinfords's Avatar
lostinfords
I will try to check to see if I have one on weds/thurs...should have it, but want to make sure
Old Jun 12, 2012 | 06:16 PM
mitchell390
Yea im sorry i didnt proof read that very good i HAVE the adjustment arm.
i NEED the bracket.
where are u finding the NOS alternator brackets.?
thanks for the information Numberdummy
Old Jun 12, 2012 | 06:37 PM
NumberDummy
i NEED the bracket.
where are u finding the NOS alternator brackets?
Ask, and ye shall receive...via the P/M I just sent you.
Since there are only two of these mounting brackets available NOS, I sent you a P/M with the info who has them.
If I post the info here, someone might snag them.
Old Jun 13, 2012 | 08:11 PM
mitchell390
thanks a million Numberdummy i will give them a call tomorrow after i get off work
Byrd.Dog
Sep 19, 2016 08:04 PM
Rhc86
Aug 25, 2016 10:22 AM
Mikey G
Aug 1, 2016 09:23 AM
RCrawler
May 25, 2009 12:21 AM
79f3504x4
Mar 22, 2002 06:11 PM
