9 inch Carrier
Old Jun 13, 2012 | 06:46 PM
JB78f150's Avatar
JB78f150
9 inch Carrier
Well I took the carrier out and found that it was cracked all the way around. When I find a new one will I have to reshim it?
Let me know what you think I should do.
Old Jun 13, 2012 | 08:07 PM
hasteranger's Avatar
hasteranger
I'd probably just find one with the same gears, get the whole drop out.
Old Jun 13, 2012 | 08:26 PM
HIO Silver's Avatar
HIO Silver
Ah, it's the Traction-Lok assembly that is cracked. Yes, replacing it would require that it be set-up again.
If you're okay with using a JY part, then go for it. However, if you're rebuilding the rig, then I would go for new (or better) gears and Traction-Lok assembly for your application (2WD or 4WD) or re-gearing for bigger tires.
Having an emergency 'spare' is always helpful.
hivoltj
25
Mar 30, 2018 01:04 PM
coolguy1419
1997 - 2003 F150
Jul 30, 2013 03:06 PM
alaskaforby4
Jun 16, 2009 04:57 PM
TheTinian
Offroad & 4x4
23
Feb 21, 2009 12:00 AM
STGFordCrazy04
Offroad & 4x4
26
Apr 19, 2008 02:00 PM
