front hub question
Old Jun 16, 2012 | 10:32 AM
Christof13T's Avatar
Christof13T
my jaw hit the counter when i guffed up and shattered a couple needles and had to make a run to orielly's ...
i think the gold is hidden deep in the middle of the castings for alien brainwave deflection... you know those guys are just looking out for us !
if that wasnt bad enough... i had to replace my half shaft as well...
xtof
Old Jun 16, 2012 | 11:19 AM
remhaust's Avatar
remhaust
Im a bit confused, u say your axle moves, or do u mean your wheel? Im sorry but you dont have to have the axle in if u sealed up the front end if u really wanted. But the axle shaft will move up and down,ect.. I guess dont know by what your saying is actually moving. Wheel/hub,steering knuckle movement(ball joints). I also agree that most vibrations would be a bent or out of balance wheel, but not always a bad hub can do this as well.
P.S
Just because the parts are new doesnt mean the are good.
Old Jun 16, 2012 | 12:44 PM
the78ranger's Avatar
the78ranger
when I say i can move my axle, I mean I can literly grab the axle between nuckle and axle tube and lift it up and down. The axle is snug in the spider gear and the carrier bearing is fine. I have new hubs both sides that are good, because when I installed them they cut the movement down alot. I have never felt this vibration till after the hubs went out. Regardless of the vibration, I don't think axles should be able to move about and 1/8th of inch up and down. ball joints are brand new and pressed and the tire,hub,nuckle have no movement. I have already bought the crazy expensive axle joints and will just install them it wont hurt anything as they appear to be original. If thats not it looks like I will keep checking down the line. Atleast i will know its not the axle joints
Old Jun 17, 2012 | 08:41 AM
remhaust's Avatar
remhaust
That much movement in the axle is perfectly fine mine moves at least that much if not more. All the axles are doing is just sitting in there and held in place with snap rings so they dont move in and out past the teeth on the hub.There is no preload on the end like on a front wheel drive car where the nut on the end of the axle holds it tight. So you will have sum play up and down which is normal.
jakesterrocks
Jan 26, 2014 01:19 AM
Mark Alligood
Nov 25, 2012 09:39 AM
RVSupply
Nov 19, 2008 08:59 PM
clydesride
Mar 10, 2007 04:24 PM
84tealbeast
Aug 6, 2006 10:49 PM
