300 ci inline 6
Old May 6, 2003 | 07:38 PM
lrac's Avatar
lrac
300 ci inline 6
I have just bought a 1984, F150 with a 300 cid 6 and stick 3 speed. I'll be using this off road and would like to change the ignition, carb etc. back to pre-polution control stuff. and maybe add a nice sounding set of duals. I had a new 66 and new 70 with 300s in them and they were both strong. What options do I have? Will earlier stuff fit this year model.
Any help/suggestions would be appreciated
Old May 6, 2003 | 08:27 PM
79_250RangerLariat's Avatar
79_250RangerLariat
300 ci inline 6
It should already be carburated, fuel injection didn't start till 87 or 88 I believe. What all do you have on there for emissions?
Old May 6, 2003 | 08:44 PM
lrac's Avatar
lrac
300 ci inline 6
Carburetor with hoses, some hooked up some pluged, EGR valve at the base on front side, several small gizmos attached to the top of the valve cover at the rear that have something to do with the carb, distributor with some type of module sticking out below the cap. I'd just like to have a plain carb and dist setup like I have on my 55. Just like to adjust the carb with a screw driver and set the timing with a plain old timing light, then drive the heck out of it. Things I understand.
Old May 6, 2003 | 08:46 PM
Franklin2's Avatar
Franklin2
300 ci inline 6
If you have a distributor with no vacuum advance on the side of it, I would change it over before something breaks. Not too many people know how to work on the early computerized carb systems. And that's what it would have if the there is no vacuum advance.
Old May 6, 2003 | 08:59 PM
lrac's Avatar
lrac
300 ci inline 6
I guess that's my question. Will carb and distributor from earlier years interchange? What years would be the best to look for? If I can get an idea what I'm looking for I can take it from there. Thanks again for the input.
Swampy78
Jul 8, 2011 09:24 AM
John 300
Oct 13, 2009 10:52 AM
51dueller
Jan 19, 2008 04:30 AM
goatman120
Engine Swaps
Jan 7, 2006 02:47 AM
Deliverance
Sep 1, 2005 07:30 PM
