Rear axle installation question
Old Jun 11, 2012 | 08:53 PM
whitley's Avatar
whitley
Learned a lot here. Thanks!
Old Jun 12, 2012 | 05:18 AM
liljohn320's Avatar
liljohn320
Tyler
Yes the sequence of the pictures is not right.
Center Section goes in first, then backing plates, then axles.
Old Jun 12, 2012 | 08:46 AM
Tyler S's Avatar
Tyler S
Originally Posted by liljohn320
Tyler
Good to know I'm not nuts.
t
Old Jun 12, 2012 | 11:34 AM
ungerp's Avatar
ungerp
The retainer flange that I refer to is the one that is secured with the four bolts that is on the outside of the bearing between the bearing and the wheel flange.
Old Jun 12, 2012 | 12:44 PM
Tyler S's Avatar
Tyler S
Got it! Thanks!
Old Jun 12, 2012 | 01:13 PM
ungerp's Avatar
ungerp
The pics are out of sequence. The axles have to slide into the third member.
pat
Old Jun 12, 2012 | 10:51 PM
Tyler S's Avatar
Tyler S
pat
Yessir. No other way. Car stuff is not always presented well. And instructions are nearly non existent. It is knowledgeable people on this forum that make this project doable for a rookie like me. Thanks for your help on this.
t
Old Jun 12, 2012 | 10:57 PM
Tyler S's Avatar
Tyler S
To wrap up this thread, the reason my axle bearings were not seating properly in the axle flange was that I had the wrong axle seals. I started with the Timken 51098 I think (about 2 1/2" dia), went down to the 9896 or something like that (2 3/8" dia), ruined one of those trying to force it, then went down to the 9896S or some such moniker (2 1/4") and it fit just right. Built the rear drum brakes today (minus the E brake, will have to come back to that) will seal the diff tomorrow and install the axles, mount the drums and wheels and I'll have a roller!! Good milestone!
t
Old Jun 13, 2012 | 06:03 AM
liljohn320's Avatar
liljohn320
Tyler
Great to hear you beat that problem. Good luck with your Father and Son build.
Send some pictures.
John
The Terrible Blob
Mar 2, 2019 08:55 PM
RAY1986F150
Sep 13, 2012 08:35 PM
polarspeed
Apr 15, 2010 05:43 PM
86CREW4ME
General Automotive Discussion
Oct 11, 2008 01:53 PM
what_the
Oct 6, 2003 12:46 PM
