axles
Old Oct 5, 2003 | 03:54 PM
what_the's Avatar
what_the
axles
1985 f150-2 wheel drive
how do you pull the rear axles, trying to replace the seals, have all the brakes off and backing plate loose, but can't seem to get axle out, what holds it in?????????
Old Oct 5, 2003 | 08:01 PM
ecarter50's Avatar
ecarter50
There are 2 different axles used in 85 F150.
8.8" uses C-clips in the differential to hold the axle in.
9" uses the 4 bearing retainer bolts to hold the axle in.
Old Oct 6, 2003 | 12:46 PM
what_the's Avatar
what_the
thank you very much, i knew it had to have something like that, but wasn't sure , thanks
