Almost Started!
Old Jun 11, 2012 | 06:38 AM
billingslm1's Avatar
billingslm1
Almost Started!
I have a 55 f100 and after sitting for 2 years i decided to try to start her up yesterday evening.
The last time i worked on her i was just finishing up over-hauling the engine, then life got in the way as it goes.
But i charged up the battery, checked the oil and hit the start button.
She tried turning over several times but i couldn't get any gas up to the carb. So i tried to syphen gas up through the hose and could hardly get any to start to pour out. THen i tried to syphen before the fuel pump and plenty came out.... Maybe a bad fuel pump...?
Old Jun 11, 2012 | 07:39 AM
raytasch's Avatar
raytasch
Believe Nothing
The valving within the fuel pump will restrict siphon fuel flow. Remove the line between the pump and the carburetor, attach a line to direct fuel away from the pump and into a container and see if any fuel discharges when the engine is turned over. Have a suitable fire extinguisher available and have the vehicle outside when you attempt this. You may or may not have a bad pump.
Two year old modern fuel is generally considered not very good fuel. You may want to consider pulling fresh fuel from a separate container.
Old Jun 11, 2012 | 01:19 PM
billingslm1
Ok ill give that a try, and it is new fuel, i already replaced the old fuel.
Thanks
Old Jun 11, 2012 | 02:21 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Good luck, just imagine how cool its goin to be when she sputters and starts. Its sounds like your very close.
Old Jun 11, 2012 | 10:36 PM
WARDNEAL's Avatar
WARDNEAL
I got my 49 running 2 weeks ago.
I had to blow in the tank to get the fuel to prime and fill the carb.
Worked for me much better than the siphon.
vidaliaman
Sep 11, 2025 09:37 AM
SimAngus
Oct 28, 2014 09:02 AM
capitanjo
20
Nov 24, 2011 03:18 PM
barrys00
25
Jul 29, 2007 03:22 PM
shawn
Jan 15, 2004 12:34 AM
