V10 vs 460 vs 7.3PSD?
I like the CC PSD, but can't afford to go new. Used ones are hard to find and more expensive than nice used V10's. I can get a nice low mile V10 for about $4 to $5,000 less than the same in PSD, and that is I get to it before it is sold.
Question: Will I regret not getting the PSD? Will the V10 tow good? Will the V10 get good enough fuel mileage to justify the $5,000 cheaper price? How will the V10 perform against my old 460, especially towing in some mountains?
Any experiences are welcome...
Thanks
I believe that all of the other questions have been discussed at great length. Were not able to find out the answers from previous posts?
Understand I want people to post but sometimes threads like these can turn into the infamous Gas vs. Diesel thread and people get a little hot under the collar in those types of threads.
Okay...on to #2. I'll give it a go.
2. Yes. But what exactly do you mean by "good"?
3. Only YOU can do the math. If you use JUST fuel price differences & MPG differences then you must use the fuel costs in your area.
4. I've never owned a 460. I am not qualified to answer that. 4x4x4x4 I think owns both.
I WAS NOT trying to "put you in your place"!!!!!!!!!!!!!!!!
Some of my comments were there for those reading waitin' to start another flaming war!
You have good questions but I think some have been covered. So a search while others post to this thread could be beneficial to you!
Always ask but always look for more info too!
In talking with the Ford mechanics, they say that many motorhome owners prefer the 460 over the V10. I am looking for experiences of "upgrading" to the V10, and how dramatic the improvement is going to the PSD. Not trying to start a diesel vs gas war...just looking for real world feedback.
Searches do not always cover the specifics I am looking for, but I can try again.
I have pulled my 5000lb trailer with mine on several trips and I got right at 10 mpg highway and I live in WV so it's fairly hilly. I wouldn't mind a diesel but I bought new and just couldn't justify the extra $100 a month it would add onto my payment. I figured it would take about six years to break even given my yearly mileage and the price of diesel in my area (which is always about 30c higher than 87).
If I was buying used I'd really consider a Powestroke though. That way someone else takes the depreciation hit and you a helluva motor that's probably just getting broken in.
Either way you can't go wrong!
Trying to find a used PSD at a reasonable price is proving to be a challenge though. I have found several NICE V10 trucks around.
I think I may go with the V10.
To do over again, I'd look harder at the PSD.
I have owned both a 460 HD 3/4 1992, and now own a 2001 F250 SD V10 so I can comment on these engines.
The 460 gas engine in my opinion was the best gas towing engine Ford ever built. It was just solid, quiet and reliable.
I pulled a 11,000# Carriage 5th wheel with it. It had a GCWR of
18500 and when I weighed it with my wife and myself fully loaded it weighed 17,800lbs. It just loved to pull if I wanted to
run 70mph it would run 70mph, same goes with 75mph but I never did those speeds after the wind took my alum domes out
on the trailer. I had a 4.10 axle with the 460.
I now have a 9000lb trailer being pulled by a V10 with a 4.30 rear axle and I never have been really happy with it. The only good thing about it is that it gets a lot better gas mileage than the 460. The engine is noisy, probably needs more engine noise abatement foam. I bought it with a 3.73 rear axle and had it changed because it was a real dog with the trailer weight.
With the 4.30 axle it is no longer a dog but it still doesn't meet my expectations for the horsepower and torque.
There is not a lot I can do at this time because trucks are to expensive to just trade-off. So make your decision right the first time if you can.
Gas mileage 460 with trailer 6 to 7mpg
Gas mileage V10 with trailer 7.5 to 9mpg
Hope this helps
fknipfer
Mileage: Slight advantage to V10, currently about 11.5 MPG; the 460 was always a little less than 10 MPG. I take about an 8 to 10% cut in mileage when towing my typical load, (7000 lbs.)
Power: Advantage V10; Baker grade, (LA to Vegas), 60 MPH in 3rd at a cruise, had to drop the 460 down to second to keep the revs up, (partly the fault of the slightly taller gears).
I do miss the sound of that big V8 exhaust, the V10 sounds like several angry Accords running in low gear.
I think the general consensus is that for towing or motorhome use, the V10 is not quite as powerful. A bit more fuel efficient, though.
Thanks for all the help. Since I will be driving quite a bit, and towing some, I have now decided to go with the Powerstroke.
I pulled my 8000-10000# camper with an 87 E350 van with the 460. It had the same carb as yours. Later I added a MSD. Two years ago I purchased a 99 E350 SuperDuty van. I expected some improvement but never expected that kind of change. It was like night and day. The pulling mpg was about the same but there was a LOT more power. The greatest challenge around here is Black Mountain on I-40 near Ashville. My speed increased from 25-30 mph to 50-55 mph going up.
Traveling without the camper I get 14-15 mpg. My wife uses it as the family taxi so the local milage is in the 11-12 range.
Granted that there may have been some difference in the rear ends but not that much. The new van has the 3.73.
You should enjoy either one you choose.
I am so tickled with my signature truck getting 13.7mpg empty, mix driving, and 9.8mpg loaded down, up the mountains, and accross I10 to el paso Tx/ Fort Hauchuca Az @ 75mph you just can't imagine!!!!!
dpoelstra you are going to be happy with either choice
Yes my 460 had much more grunt, but I am a lead foot, and I usually have TWO big twin Harleys in the bed and a 22' bumper drag hooked up for long weekends. The V10 on 87 octane and with NO MODIFICATIONS (3.73:1 LS rear) takes me up the steepest grades with out going down to 2 gear.
Count me as a Ford V10 lover and one HAPPY Camper too
