Sponsored by: Auxito
Electrical charge coming from bumper
Old Jun 10, 2012 | 09:11 PM
Ford Blue 2000's Avatar
Ford Blue 2000
2000 F150 5.4
I was cleaning the battery posts tonight. I was leaning against the bumper when I touched the positive cable and got voltage into my knee. I have had weird electrical problems occasionally. Any ideas ? Thanks in advance
Old Jun 10, 2012 | 10:10 PM
steve(ill)'s Avatar
steve(ill)
bumper is grounded to the negative side of battery. If you touch the positive and leak against the negative, it is possible to get a thrill. Especially if you have wet/damp hands or jeans.
Old Jun 11, 2012 | 03:54 PM
Ford Blue 2000
Ive had weird electrical problems, so, I think its something else.
Old Jun 12, 2012 | 02:17 AM
BFTUFF's Avatar
BFTUFF
There may be an intermediate short some where. You'll have to inspect the cables and wiring for ground shorts, something wearing against a grounding point.
Old Jun 12, 2012 | 06:48 AM
projectSHO89's Avatar
projectSHO89
If you're putzing around the battery cables without disconnecting one of them (negative), then the shock you received was the equivalent of a "dope slap" to wake you up.
Old Jun 12, 2012 | 12:18 PM
Bluegrass 7's Avatar
Bluegrass 7
Put another way, the battery has the stored chemical energy.
Since the negitive post was still connected, it has connection to all metal parts of the truck.
With your hands on the positive post, YOU provided enough LOW resistance to allow current to flow.
Since your human 'i assume' you are able to feel the low amount of current through your body same as a voltmeter would show.
Very specificlly you completed the circuit through you from one side of the battery to the other.
When that is done no matter how, 'electrons' are attracted from the neg side to the positive side. This is current flow you felt.
This has no relationship to your electrical issues.
Do the same on another truck and you will get the same result as long as the same conditions exist..
Good kuck.
coreyallan01
Maine Chapter
May 17, 2016 08:06 PM
fordsuperduty250
Dec 24, 2012 01:22 PM
dehamma
May 3, 2008 09:29 PM
uncle2abc
1983 - 2012 Ranger & B-Series
Jun 10, 2007 04:01 PM
