32 psi boost good or bad
I was messing around on the highway the other day and got on the truck. Boost gauge topped out at 32 psi, but didn't feel/sound like it was really going anywhere. Almost felt like the torque converter wasn't unlocked because sometimes it'll take off and the exhaust is real loud at high speeds and others, it'll just boost and the exhaust will be quiet. I get a wrench light when towing at highway speeds, but no CEL. I did show a over/under boost code once when driving about an hour and a half up hills towing and the wrench light kept showing its face. Every time it'd come on I'd pull over, shut it down, restart and keep trucking. Anyone know why this thing is being like this?
06 f250 66k
06 f250 66k
P0234
Turbocharger over boost detection code stored and wrench warning lamp illuminated when a turbocharger over boost condition occurs. TSB 09-24-03. The only trucks that will set an overboost code P0234 are the 05-07s with the latest ford calibration. The calibration will set the wrench light and derate after 28 PSI
IIRC you shouldnt go over 28psi Boost and at this Point the PCM should set a DTC
But you have to make shure the Boost psi your seeing is True or is the Gauge Reading it right
This is where you have to becareful with tunners
