'69 Wire harness color code ? need help.
Old Jun 10, 2012 | 08:47 AM
alvald83's Avatar
alvald83
I am getting ready to wire up to a 7 wire camper plug. My camper special already has the flat 7 wire plug but I intend to replace it with a 7 round plug.
Since my plug seems to be an untouched original plug, I was assuming I could just go by the factory wiring diagram. That's the problem, I can't fing the wire color code. I can find the diagram that's names the color, but nothing that says what it's for. I know I'm being lazy (I could test every wire) , but my connector has about 6" of the harnes hanging out next to the gas tank under the bed, so it's in a awful spot to try to test each.
My plan was to get the color code and cut and splice the new colors and run them up to a easier spot to do my final testing before connecting the new plug. Too bad some one doesn't make a adapter harness. Thanks for your help. Al
Old Jun 14, 2012 | 11:35 AM
Freightrain's Avatar
Freightrain
Here is a link to the typical 7 pin wiring diagram:
Take your pick
7 pin trailer wiring - Google Search
Are you speaking of flat blade(RV style) to 7 pin(semi type)?
danjenlily
Jul 30, 2018 11:04 PM
Notmeofficer
Jul 14, 2017 06:46 PM
g888642
Bronco II
Jul 31, 2006 06:48 AM
Ken86F350
All Things Towing
Dec 16, 2005 05:13 PM
Steve
Electrical Systems/Wiring
Nov 25, 1999 10:41 AM
