Making a dually
Old Jun 9, 2012 | 07:20 PM
fourboltmain3401's Avatar
fourboltmain3401
4wd Low
Making a dually
Ok, how hard is it going to be for me to turn my 1973 F-250 Camper special Into a Dually F-350? I have a dually Dana 70 from a 1980 F-350 to put in, any info on this is greatly appreciated.
Thank's,
Kenny.
Old Jun 10, 2012 | 08:52 AM
teds74ford's Avatar
teds74ford
I would think you might have to weld on new perches, and maybe shorten the driveshaft. For the front, you can buy dually hubs/rotors and swap them.
Old Jun 10, 2012 | 08:58 AM
FineSeventyNine's Avatar
FineSeventyNine
Tennessee Hillbilly
If you're planning on using it for what a dually was designed for......increasing your GVWR...........you will need much more modifications.
The '79 F350 I have was originally a cab and chassis........now with a dump bed.
The rear part of the frame is much wider and taller than my F250 and it has a rather large stack of
main springs in the rear, plus overloads. It has the dana 70 axle.
Coltin1992
Oct 28, 2016 03:03 PM
Notmeofficer
Oct 28, 2016 06:55 AM
1999stroke
Dec 26, 2007 07:03 PM
kevbits
Dec 16, 2007 04:59 PM
jd131313
Feb 27, 2006 09:39 PM
