Sponsored by: Kumho
$710 alignment...
Old May 6, 2003 | 06:08 PM
rhetor's Avatar
rhetor
$710 alignment...
Took the truck in today for an alignment... turns out it needs $710 worth of bushings, bearings, and ball joints.
Is $710 too much money for all that crap and an alignment?
I'm very unhappy. I don't have $710. If i don't find the cash though, trucks gunna start wearing down the tires real bad... grrr....
Its hard makin $710 on a $20 a month income... you know?
Old May 6, 2003 | 07:30 PM
mustange70's Avatar
mustange70
$710 alignment...
if you do all the bearings bushings, and seals yourself you can save quite a bit (probably around $200). You will probably wan't to get them to the alignment though. Shop around to cause different shops will charge different for labour and parts.
Old May 6, 2003 | 08:14 PM
rhetor's Avatar
rhetor
$710 alignment...
Don't i need some sort of tool to pressure punch the bearings/bushings/ball joints?
I don't have the tools neccessary to do that...
I'll ask a few shops close by... i'm still too ****** off to really help myself too much.
Looks like no lunch for a few weeks...
Old May 8, 2003 | 06:40 AM
rabidranger's Avatar
rabidranger
$710 alignment...
All you need are the hub socket, some regular sockets a BFH to get the knuckle off the ball joints, and the same to hammer them out of the knuckle. Just did mine 2 weekends ago. Upper and lower ball joints plus new wheel bearings for about $225 in parts. It took about 2 days though, so plan accordingly.
Old May 8, 2003 | 08:02 AM
Sycostang67's Avatar
Sycostang67
$710 alignment...
If your truck is 2wd, the hardest part would be the ball joints, none of the bushings need to be pressed in except for maybe the I-beam pivot bushings, I have never done those before. Bearing and bushings are a snap. Make sure you take your truck a few other places, I did some suspension work on a 71 LTD, and told the girl where to take it for an alignment, and she took it somewhere else where they told her I did everything wrong, and that it was gonna cost $1200 to fix. I told her to give me the car, I took it where I told her to take it, and there wasn't a dang thing wrong with the car, 1/2 hour for an alignment and I was on my way. Supposedly her friend worked at the other place.....some friend.
Old May 9, 2003 | 09:31 PM
bronco351's Avatar
bronco351
$710 alignment...
The last alignment I did on my 1990 Bronco (6" Lift) cost me a tad over $400!! I thought that was a good price!!
Old May 10, 2003 | 04:54 PM
rhetor's Avatar
rhetor
$710 alignment...
Thanks for the replies... I was considering doing it myself, but my dad already made an appointment for it to go in on tuesday. He's gunna loan me the money so i can pay him back in the summer.... thanks dad.
Old May 10, 2003 | 07:35 PM
ford5.8's Avatar
ford5.8
$710 alignment...
80,000 miles and u already need all that stuff??
Old May 11, 2003 | 11:41 PM
tack338's Avatar
tack338
$710 alignment...
I am going to change my drag link soon and found that Auto Zone will loan tools free of charge, just a deposit is required. I hear there is a tie rod puller, Sounds like it will work much easier than smacking a pickle fork between the joints and possibly tearing up the rubber seals. If all your parts are and good, just the alignments should start at 29.95 if only adjustments are required, GOOD LUCK!
