Window Track Lube
Old Jun 9, 2012 | 12:07 PM
Liquid10Rider's Avatar
Liquid10Rider
Window Track Lube
Hey guys. My windows are going down slower, and I've heard people talking about greasing up the tracks, but I don't know what to use. Is there something in particular that I should use?
Thank you,
-AJ
Old Jun 9, 2012 | 12:50 PM
honeydew's Avatar
honeydew
I've seen several posts where people said silicone spray works well.
I use this stuff but it's expensive and I already had it.
VW Sunroof Grease - G00045002 - IDParts.com
Old Jun 9, 2012 | 02:02 PM
BigAlsPSD's Avatar
BigAlsPSD
I use oring lube, you can get it at most home improvement stores. It is designed for lubing o rings in faucets, and is like a really thick vaseline.
Old Jun 9, 2012 | 04:28 PM
Tugly's Avatar
Tugly
I'd be more inclined to use powdered graphite. It will likely embed in the tracks and it doesn't draw dirt and make a paste. If I'm wrong on this, you can always try a wet lube - but you can't un-oil the track if you try that first.
The motor might be getting weak. If lubing doesn't square it away, you might need to take the motor out and see if the brushes can be replaced (I doubt it). When replacing small DC motors, I always try electric motor shops before I go to the stealership.
Tugly
39
Dec 8, 2012 09:20 AM
Terry SD
Nov 2, 2012 12:51 PM
Tugly
44
Mar 16, 2012 05:54 AM
slim613
15
May 30, 2011 06:50 PM
JoeKramer
Jan 9, 2005 11:13 PM
