Big Power?
Old Jun 27, 2012 | 09:57 PM
  #31
PaysonPSD's Avatar
PaysonPSD
Originally Posted by 351Cleveland C4
yea i just want about what you got PaysonPSD,, but if i get to 500/1000 thatd be great!
I listed what I did so you would have a starting point for about 450. Bigger sticks with the right tuning will get you 500.
But as mentioned before get it running at its peak in stock form before adding power mods.
One thing I didn't mention was a fuel return to open up the deadhead fuel rail on each head.
Old Jun 28, 2012 | 12:02 AM
  #32
Bonanza35's Avatar
Bonanza35
Robin, did you make your own fuel return or use Clays FRX?
Chet
Old Jun 28, 2012 | 07:39 AM
  #33
mueckster's Avatar
mueckster
When looking at numbers north of 400 rwhp, I recommend a regulated return system with larger fuel lines and get rid of the check valves in the heads. I built my own with an Aeromotive adjustable regulator, AN PushLok fittings, and synthetic nylon braided hoses with Otiker clamps. The change to a full regulated return, over my homebuilt CCK (similar to FRx), netted me ~35 more hp and 100 ft-lbs tq.
Robin and I's hp and tq numbers are very similar; and our injectors flow about the same rate.
Old Jun 28, 2012 | 09:38 AM
  #34
PaysonPSD's Avatar
PaysonPSD
Chet
My fuel return is the CCK that was produced by Dino Fuels Alternatives. It was the budget (allthough high quality) fuel return at the time. Still functions just fine and had an 1/8" NPT port where the two fuel rail crossover lines tee together that made it a snap to plumb in my fuel pressure gauge. Instead of measuring fuel pessure at the fuel bowl this arrangement lets me measure the fuel pressure post injectors.
DFA specialized in products for WVO as a fuel and was bought by a larger company and the CCK is no longer available. I've had the CCK installed for about five years. If Clay's FRX was available at the time I would have gone with it, much easier install.
Old Jun 28, 2012 | 06:04 PM
  #35
Bonanza35's Avatar
Bonanza35
Thanks Robin, I have Clays right now. I didn't take out the check valves as mentioned above in the stock locations.
Chet
Old Jun 29, 2012 | 10:26 AM
  #36
PaysonPSD's Avatar
PaysonPSD
Chet
I've still got the check valves and unless you're going for huge HP just leave them alone. Post injectors I have 70 PSI at idle and 65 PSI at WOT so they don't seem to be all that restrictive.
Tugly
Computer Chips & Tuners
Apr 10, 2014 05:10 PM
sudsmcduff
Sep 23, 2012 08:05 PM
Tugly
Dec 13, 2011 05:36 AM
f1501987
Nov 22, 2011 05:05 AM
