Picked up my new 6.7 SD last week. Having an awesome time driving it. I know, I will post a picture when I get it washed up. I am looking at purchasing an Edge insight CTS, what information does it tell you? The factory web is very vague other than it fits anything newer than 96. Do I need to hook up /purchase other sensors like EGT? Does the dash mount look seamless in a 2012?
Kicker, The Edge Insight will display any of the PIDs that your trucks computer tracks, That is about 40 different PIDs to choose from. I found most didn't mean much to me. But Voltage, EGT 11-14, Soot %, Engine Coolant temp etc were stuff I had an interest in.
The display is configurable from 3 to 8 displays and you choose what goes in each display from the list of PIDs in the PCM.
The truck has 4 Pyro sensors in the exhaust stream. But none of them are pre-turbo. In fact EGT11 is 3-4 feet downstream and just in front of the cat. If you want true pre-turbo temps, You will need to install a sensor for that.
Stock truck won't get too high. PCM will defuel if you approach the limit Ford programed in. I suggest you watch you guages as you drive in stock form and get used to what normal temps are. Then IF you tune the truck, You can watch for excessive temps.
Mine normally won't exceed around 900°-950° with normal towing, During regen I'll see higher temps, especially in the sensor in the DPF where I frequently hit 1200°
Too bad there is not a way to get more information displayed in the digital center cluster. It seems to want to tell me everything else... I am really only interested in %soot and EGT. An advanced mode or something like that would be real cool. Along the same lines the Nav systems have a GPS but you are still limited on speedometer settings. You would think they could set up an auto calibrate.
Off to install the Epic door mods, After a half a day in the service dept the wind noise is still there.
