Edge Insight mounting
Old Jun 15, 2010 | 09:59 AM
chrischaugen's Avatar
chrischaugen
I've been looking all around the forum, and I've seen some conversations about it, but can't find anything definite. I've decided to purchase an Edge Insight, but would like to have it mounted in the pillar instead of using the dash mount. Looking around, I've seen a pillar mount for the Edge Attitude, but none for the Insight. Does anyone know if the Insight will fit into the Attitude pillar mount? Or am I stuck with the dash mount?
I have a 2003 F-250 PSD, 2WD, LB, CC...
Thanks for any input!
Old Jun 15, 2010 | 12:21 PM
bpounds's Avatar
bpounds
Yes, it is the same unit with different firmware.
Here is someone's pillar mount:
and here is my dash mount:
Old Jun 15, 2010 | 12:39 PM
chrischaugen
Thanks bpounds...the pictures were especially helpful. And just to make sure, it looks like they are both in close proximity to each other, so the extension cable will NOT be needed correct?
Old Jun 15, 2010 | 12:41 PM
bpounds's Avatar
bpounds
Yes, they will be long enough. In fact, they were very generous with both cables. I had to roll and tie up quite a bit extra. Not enough to reach overhead, but plenty to reach the pillar.
Old Jun 15, 2010 | 12:43 PM
chrischaugen
Awesome...thanks! Ordering right now...
Old Jun 15, 2010 | 02:36 PM
w_huisman's Avatar
w_huisman
I have both mounts. Currently I'm using the dash mount because it's easier to remove than the a-pillar mount, in case I need to make a dealer visit. However, once my warranty is up this coming December, I'll be using the pillar mount because it holds the unit closer to my driving line-of-site and at a better angle so that I am less likely to forget to keep an eye on it.
It's a minor difference between the two, but it makes the a-pillar mount better than the dash mount IMO.
Old Jun 15, 2010 | 03:00 PM
chrischaugen
w_huisman...Is there a significant difference in the glare on the screen between the dash mount and pillar mount during the day?
I thought that being the Insight is only a monitoring device, that dealers shouldn't / wouldn't care that it's there...am I mistaken with that assumption?
Old Jun 15, 2010 | 03:15 PM
w_huisman's Avatar
w_huisman
I don't notice a difference in glare. During the day I crank the backlight up, and in the dark I turn it all the way down to one or two settings above the off setting. Seems to do the trick.
I never assume anything when it comes to dealerships. Based on peoples experiences I've read about on the forums, dealerships vary from one extreme to the other when it comes to warranty work on trucks with reliability and performance modifications.
If you don't have the factory warranty, don't worry about it.
Old Jun 15, 2010 | 03:27 PM
chrischaugen
Thanks for all the great info! I can't wait to receive mine and start playing with it!
Old Jun 15, 2010 | 03:28 PM
rocky1074's Avatar
rocky1074
It's just when some dealers see a gauges or other devices some are quick to assume you are running tunes or something else. My truck is stock as far as tunes I just have the insight to protect my engine and to catch a problem in time..
Old Jun 15, 2010 | 03:32 PM
chrischaugen
Kind of off topic, but dealing with the same equipment, when ordering either the dash mount or pillar mount, do you get to specify a color? Or does it come in a certain color and they provide the paint, if needed? Or will I have to go somewhere to match the color and paint it myself?
Not a big deal, just curious for those of you that have this installed already. Thanks
Old Jun 15, 2010 | 03:36 PM
bpounds's Avatar
bpounds
The dash pod will come natural plastic colored. Kind of a medium gray. I painted mine in the picture above with a flat black, and it matches very well. I can't speak for the pillar pod.
Old Jun 15, 2010 | 03:41 PM
w_huisman's Avatar
w_huisman
Neither of my mounts came with paint, nor did I paint either one.
My dash mount came in gray, and my a-pillar mount is black. My interior is black and gray (with some wood colored trim), so they both match well enough for me.
My dash mount...
My a-pillar mount....
Old Jun 15, 2010 | 04:06 PM
bpounds's Avatar
bpounds
Originally Posted by bpounds
I know the OP is leaning toward the pillar mount, but thought I might note what paint I used for anyone else considering the dash pod.
I used this stuff:
Click on the can for info on the product.
Old Jun 15, 2010 | 04:18 PM
chrischaugen
Thanks for that info bpounds. I would imagine that no matter what mount a person decides to use, that product should work for both mounts if they need to be painted.
Thanks again!
