UVCH
Old Jun 8, 2012 | 02:38 AM
1L243's Avatar
1L243
UVCH
I have a 1999 e F 250. I am thinking of replacing the valve cover gaskets to fix the UVCH once and for all. I started having intermittent loss of one side about a year ago. I used the Ford OEM shims on both sides. I was fine for about 8 months but it has happened about four times in the last four months. No duration when it happens I just pull over turn off the truck turn it back on and it's fine again.
Anything I need to know about replacing the valve cover gaskets? Should I just get them from Ford?
Old Jun 8, 2012 | 04:33 AM
BigAlsPSD's Avatar
BigAlsPSD
Ford or Clay
Simple remove and replace. You might consider new harnesses as well.
http://www.riffraffdiesel.com/mm5/me..._Code=F731-OEM
Old Jun 8, 2012 | 11:16 AM
1L243's Avatar
1L243
If you don't replace the harnes is that leaving half of the connector?
Jzmm
Jul 24, 2018 09:22 AM
Resendiz
Oct 18, 2016 08:56 PM
wreckinball
Jan 13, 2011 11:07 PM
reefdiverbob
Jun 10, 2006 10:55 PM
Bomber_Boy99
1978 - 1996 Big Bronco
Apr 2, 2001 06:24 PM
