valve cover gaskets
Old Jan 12, 2011 | 09:39 PM
wreckinball's Avatar
wreckinball
valve cover gaskets
Fellas,
How long should a valve cover gasket last? Mine on the drivers side seems to be leaking around the very back tab if you know what i mean, the little tab for installing on the cover. I cleaned it and it came back so obviously leaking. They arent hard to change but ford only gave me one year. So its on me to change. How long should i expect? did ford mess it up if it only lasted a bit over a year?
Old Jan 13, 2011 | 07:22 PM
BlueOvalBud's Avatar
BlueOvalBud
I don't know how long they should last, I would assume a while...but I have to say mine are leaking after a year also...passenger side rear area.
I think they were the cork ones, what are yours?
Old Jan 13, 2011 | 08:55 PM
wreckinball
ford factory black rubber? i think haha. I am going to get some felpros and call it good. Cheap and easy as hell without a turbo on haha.
Old Jan 13, 2011 | 09:00 PM
mikecwik's Avatar
mikecwik
my nuts seemed to loosen up repeatedly for about 7 months and then they quit leaking but i guess that you checked that.
Old Jan 13, 2011 | 09:02 PM
wreckinball
first thing i did was check them to see but they were good. These things sure do rattle though haha. when i reinstall i will probably use a moderate to mild thread compound. this will take no more than 30-40 mins if something goes wrong. But as you know i will probably paint them while i have them off haha. hmmmm what color to do....
Old Jan 13, 2011 | 09:04 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Both valve covers on my 7.3 have been leaking for years, they are the originals, I never ever took the covers off.
The last year the truck was on the road, it was getting so bad that when you got on the highway, after driving about 5 min, it started smoking blue and smelling like burnt oil inside the cab, the oil was burning off the manifolds, had to roll down the windows when ever that happen and usually took around 5 to clear up, then it was fine.
The 6.9 on the other hand is a nice leak free engine, I did replace the valve cover gaskets 7 years ago when I did the head gaskets, but they hadn't leak before, and the new ones haven't yet either.
Old Jan 13, 2011 | 09:08 PM
frodfreak's Avatar
frodfreak
i would go wit the good ol ford blue.....but no orange it makes things over heat
Old Jan 13, 2011 | 11:07 PM
wreckinball
thinking of a unique color, not sure yet, possibly a hightemp dark metallic grey, lordco carries a lot of hightemp paints so we shall see! hahaha
Smily738
1997 - 2003 F150
May 17, 2022 06:15 PM
chiefsfootball
34
Dec 26, 2018 05:45 PM
OrangeJuice
Jan 17, 2010 05:59 PM
dustinova
May 4, 2007 11:38 PM
JBronco
1978 - 1996 Big Bronco
Oct 10, 2002 01:59 PM
