Sponsored by: Real Truck
Cruise Control Issue
Old Jun 7, 2012 | 08:09 PM
96DRW's Avatar
96DRW
Hello - My CC has not worked in my 2000 F250 since purchase a couple of months ago. I replaced the sending unit on the master cylinder because it was leaking oil. No change. I initiated the self-test diagnostic and got one flash indicating the diagnostic mode started and one flash after pressing the "On" button. No other flashes occurred. Can I assume it's a bad switch? Thanks for any help.
Old Jun 9, 2012 | 09:03 PM
96DRW's Avatar
96DRW
The CC is working I replaced the brake cut-out switch and did the CC diagnostics without a road test between procedures. FYI - if your CC is not working, replace the brake cut-out switch first. I'm still wondering why the diagnostic test was weird? Anyway, it works.
Old Jun 11, 2012 | 07:12 AM
Budman1962's Avatar
Budman1962
Is this the sensor on the master cylinder? I get no flashes on self-test diagnostic.
Old Jun 11, 2012 | 04:08 PM
96DRW's Avatar
96DRW
I replaced the sensor on the master cylinder. I believe it is the sensor that kills the CC when the brakes are applied. The sensor appeared to be leaking. It was a 20 dollar part and took a couple of minutes to RR.
Old Jun 11, 2012 | 05:26 PM
projectSHO89's Avatar
projectSHO89
SCDS - Speed Control Disconnect Switch
Pick up the recall kit as it includes anew fused harness. See the dealer parts department.
JohnC4X4
Aug 23, 2019 03:26 PM
SuperDutyScaler
1997 - 2003 F150
Apr 6, 2018 12:52 PM
Christof13T
Oct 9, 2013 09:47 AM
SVT03
Nov 19, 2007 11:42 AM
Jaaaaaaackman
Sep 21, 2007 09:33 PM
