front poping
Old Jun 7, 2012 | 01:45 PM
baker1983's Avatar
baker1983
front poping
Ok iv got a 96 f 350 2wd iv had a poping noise for a while now iv replaced radius arm bushings axle pivot sway bar endlinks and bushings including ball joints tightend fender bolts could body bushings pop or brakes in anyway
Old Jun 7, 2012 | 02:07 PM
fordman67's Avatar
fordman67
If it is when you steer.i had one that the engine crossmember and frame rail on drivers side. The rivet had come loose.i welded the two together and it was good.
Old Jun 7, 2012 | 02:37 PM
baker1983's Avatar
baker1983
Its all the time forward reverse left right when i hit the brakes
Old Jun 7, 2012 | 02:47 PM
Talyn's Avatar
Talyn
FENDER BOLTS!
Old Jun 7, 2012 | 03:25 PM
baker1983's Avatar
baker1983
Originally Posted by Talyn
FENDER BOLTS!
I tightened all of them when i put new bolts in to straighten it
Old Jun 7, 2012 | 03:29 PM
ReBilld's Avatar
ReBilld
Is your radiator support cracked on the top at either side of the radiator? Most of them are, could be that flexing and popping.
Old Jun 7, 2012 | 03:40 PM
baker1983's Avatar
baker1983
That could be it some dumb a hole cut mine at the top befor i bought it so i fixed it w angle iron
Old Jun 26, 2013 | 01:34 AM
pilgrimbizket's Avatar
pilgrimbizket
What causes the cracking of the core support? Is this a common issue?
Mine was cracked up top. I welded it back up.
Old Jun 26, 2013 | 03:08 PM
ReBilld's Avatar
ReBilld
Don't know why they crack, but almost every one I've had is.
Old Jun 26, 2013 | 07:53 PM
pilgrimbizket
Ohhh what a sigh of relief I was worried about that
Old Jun 27, 2013 | 12:47 AM
Stroked 89 CA's Avatar
Stroked 89 CA
check track bar bushings also
Old Jul 4, 2013 | 08:57 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
i went threw this as well. i tightened down all my fender and hood bolts and the issue went away. i also have all new bushings on the front end as well.
Old Jul 5, 2013 | 08:36 AM
fordman67's Avatar
fordman67
It did it mainly just at the end of steering travel...your sound is differnt it sounds worse
baddad457
17
Dec 15, 2013 02:47 PM
TractorM3
Mar 16, 2006 08:44 PM
135crewchief
1978 - 1996 Big Bronco
Feb 26, 2006 05:40 PM
twallace
Jul 31, 2004 09:34 AM
Mexray
Apr 6, 2002 04:47 PM
