clunk in front end
Old Mar 14, 2006 | 07:05 AM
TractorM3's Avatar
TractorM3
clunk in front end
well ill say it best i can. i have a clunk comming from my FRONT END. its sounds like a rubber mallet hitting the frame rail. it clunks once when i brake and wont again unless i release and hit the brakes again. it also happens when it goes from stop to moving some times! now its a 94 f150 4.9 2wd standard tranny, twin i beans in the front. i can tell you what its not. its not ball joints, its not steering linkage, its not the radius arm bushings or brackets, its not the shocks, its not the wheel bearings, and im pretty sure not the brakes. it only things i can think of is 1) the i beam bushings where it bolts to the frame, or 2) the engine mounts but i dont think its the mounts because the cluck isnt throttle sensitive. like it doesnt change when i hit the gas or let up. it doesnt make a difference weather its in neutral or drive its all the same. not things i have questions about it the drivers side ball joints. i know they are pressed in and have to be flush (flat) on the metal. it gets wierd, on the top of the upper ball joint there is an un-even lip on it like it was not pressed square into the axle. but if you look at the bottom of it, the lip it evenly pressed in. possible problem? well offer up any thing you have to offer. stuff to check or look for, any thing will be apriciated
Old Mar 16, 2006 | 06:32 PM
alz's Avatar
alz
First thought is radius arm bushings. You say they are ok. Maybe check again? Just a thought.
Old Mar 16, 2006 | 07:25 PM
nugecrazy's Avatar
nugecrazy
jack the truck up and move the tires to see if its the radius arm bushings.
Old Mar 16, 2006 | 08:44 PM
Kansas-Mike's Avatar
Kansas-Mike
My F250 was making noise. It turned out to be a broken pivot bracket.
bumpdraft
Dec 2, 2014 11:01 AM
'94IDITurbo7.3
Feb 11, 2013 05:08 PM
nashvegas99
Dec 24, 2012 11:51 AM
ChristopherN
Apr 25, 2011 03:50 PM
rednekrebel28
20
Dec 29, 2010 07:45 PM
