Upside down steering wheel
Old Jun 7, 2012 | 01:39 PM
naf's Avatar
naf
Had an collision where I sideswiped a stopped pilot with right fender and door of my 97 ranger while turning right. Afterwards steering wheel was upside down ! Tire does not appear to have been hit although truck may have moved to left. At shop, but no clear answer as to how this happened - ideas?
Old Jun 7, 2012 | 08:20 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
The connection between the frame mounted steering gear and the steering column would be one cause. Another would be that the steering wheel is mounted with splines that can slip under abnormal torque. With the front wheels aligned to the front, loosen the connection at the steering gear and see if the steering wheel will rotate back into the proper position. If that works tighten the connections back down. There is a semi-flexible joint between the steering column and gear. It is called a jack shaft or sometimes a rag joint. It's purpose is to eliminate small vibrations that might otherwise be felt in the steering wheel. I have done almost the same thing driving across a rough plowed field chasing Coyotes while shooting out the window and driving into a 5 foot deep wash out.
Old Jun 7, 2012 | 10:28 PM
Furyus1's Avatar
Furyus1
I bet that was fun...
Old Jun 8, 2012 | 07:47 AM
wp120470's Avatar
wp120470
That's what I'm talking about!
Old Jun 8, 2012 | 08:34 AM
tmcalavy's Avatar
tmcalavy
coyotes, pilots and washouts...oh my...either of you take/pass drivers ed?
Old Jun 8, 2012 | 01:28 PM
naf's Avatar
naf
Thanks,
Shop initially told insurer that it was pre-existing ! Then they partially pulled column and reset it . When I picked it up from bidy shop, AC vents not working - air only on windshield - again shop said pre-existing (winnerworld auto). Took to my guy who reconnected vacuum connection at fender can.
Meanwhile back to insurer and shop as alignment pulling right - I beam not right.
Back to my guy when insurer shop done.
djmichael24951
Dec 6, 2015 04:34 PM
atomrat
Jul 13, 2014 06:56 PM
CR125Honda
18
May 3, 2013 08:37 PM
countryshiz87
May 26, 2012 02:38 AM
meborder
May 12, 2012 03:02 PM
