6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Is 10mpg possible?
Old Jun 6, 2012 | 09:08 PM
SPCRacer51's Avatar
SPCRacer51
Is 10mpg possible?
I have a 2010 F-350 6.4l ps cc drw 3.73 that im using to tow a 48ft enclosed gooseneck race trailer with 1ft extra height and is square as a box. With the trailer empty im figuring im at about 16k-17k lbs. My boost sits 20psi depending on the wind at about 55-60 mph and am getting 6.5-7.2mpg(hand calculated). Now when fully loaded to go racing im guessing ill be right around the GCWR of the truck at 23,500lbs, now is it possible to get near 10mpg with what I have described? If I dont have enough information let me know any help would be appreciated. I have a picture of my setup but I dont know how or if I can upload from my phone.
Thanks Scott
Old Jun 6, 2012 | 09:28 PM
RM2738's Avatar
RM2738
Just to clarify... You're getting 6-7mpg towing an empty trailer and you want to get 10mpg towing it fully loaded?
Fully loaded or not, if you want to go from 7 to 10 mpg, you're talking a 45-50% increase in fuel economy. I'm sure you could do a combination of things to potentially get 1-2mpg's but I think you're asking for a lot.
Can you put a v-nose on the trailer? Synthetic fluids in your truck? Delete the DPF,DOC,EGRs? Add intake?
What type/size tires? 4x4? Standard? Auto?
Old Jun 6, 2012 | 09:41 PM
Tom's Avatar
Tom
The biggest thing that you can do for your fuel economy has to do with your driving habits. I have no idea how you drive or anything, but if you slow down to 55 or 60 MPH, coast to stops, and remember that each time you touch either pedal you're burning fuel you can improve by as much as 25%.
Old Jun 6, 2012 | 09:43 PM
galaxie641's Avatar
galaxie641
10mpg at 24K I don't think so, I am in the 8mpg range at that weight but do still have the DPF and EGR so deleting them should help a little. Your empty mileage seems a little low but not by much because of the resistance.
Easiest way to do pics is upload them to photobucket then link. PB app will do the uploading to their site automatically from your phone.
This was my worst mileage to date and about 24K GCVW, mileage was under 8 but it was in regen the whole time:
Old Jun 6, 2012 | 11:32 PM
SANDDEMON08's Avatar
SANDDEMON08
Thanks Scott
I'm assuming your trailer is about 8,000 lbs, Truck should be about 8500 putting you around weight mentioned above. 7.5 seems very low at that weight. At 26,000-30,000 gvw I'm around 7.5-8.5. At 16,000gvw I'm around 12 no problem running 65. Empty you should get your 10-12 depend how you drive, loaded it's not gonna happen.
Old Jun 7, 2012 | 12:09 AM
rrrrick's Avatar
rrrrick
I have a 2005 F-350 DRW Crew cab and tow a 44' gooseneck racecar trailer. The two bestthings I did for fuel mileage so far is I put a wing on the truck and that helped some, but the best thing for mileage was I built a deck on the bed to stand on from the cab to just in front of the gooseneck hitch and I picked up an extra 75 miles to the tankful
Old Jun 7, 2012 | 12:21 AM
SPCRacer51's Avatar
SPCRacer51
First off thanks for the replies. I should have said id love to see 10mpg loaded but would easily settle for 8-8.5 consistantly. To answer some of your questions no v-nose, its a automatic 4x4 bone stock other then the hitch and I drive like a grandma roll into it slowly and give myself plenty of space to stop(no sense in beating on the truck). I have found I get my best mileage at "highway" speeds around 58-62mph(dont go ove this speed unless im going down hill) and the rpm are at or just below 1750 at that speed. Im on my computer now and im including a picture of the truck and trailer so you can see what im dealing with. Thanks again
Old Jun 7, 2012 | 05:00 AM
senix's Avatar
senix
I don't think you can get much better without the delete and even then not that much difference.
I am in the 7-9 range pulling my 5er. The wind takes its toll.
Old Jun 7, 2012 | 09:21 AM
StanleyZ's Avatar
StanleyZ
Before I deleted my dpf I was in the 8 to 9 MPG range with a lot of runs in hard conditions (monutains or wind or even hilly) in that 6.5 to 7.5 range. I deleted with a very mild (+ 35 HP) tune and hand calculated 10+ on 6 different trips. All 6 trips were on pretty easy terrain so I expect when I get back in the mountains I'll drop off some.
Old Jun 7, 2012 | 10:39 AM
SPCRacer51's Avatar
SPCRacer51
Is it like half a tonneau cover? Then was the 75 mile/tank increase from both or just the stand and do you have any pictures?
Old Jun 7, 2012 | 10:43 AM
SPCRacer51's Avatar
SPCRacer51
Is the mileage you are or even were seeing because of the 4.30 rear end? What is your mileage without the trailer before and after the delete? Because with the trailer in your picture those seem like pretty stellar numbers to me.
Thanks again to everyone for the replies
Old Jun 7, 2012 | 03:50 PM
StanleyZ's Avatar
StanleyZ
I don't drive enough without the trailer on the highway to ever get a good read. In town driving while on vacation was around 14.5. And as you say with the 4.30 I'm not complaining. And I drive it like an old man, cause I am an old man. Tow at 60mph, 1950 RPM. i stay at that speed unless I'm impeading traffic then I try to keep up.
Old Jun 7, 2012 | 04:57 PM
Tom's Avatar
Tom
Remember that weight has virtually no bearing on fuel economy when you're on the highway. When my 24' enclosed trailer was empty(3,500 lbs), my 6.7L truck would get 10.5 MPGs; when loaded to 12,000 lbs I would see around 10.0 MPGs. Wind resistance is the most important factor, and that 48' box is what is causing all the drag. Whether he's at 8,000 lbs or 25,000 lbs his fuel economy will be awful.
Of course the inverse is true around town because of slower speeds and the stop and go.
motownbrowne
Sep 20, 2012 11:50 AM
96mustangV6
May 8, 2012 09:02 AM
lawnspecialties
6.7L Power Stroke Diesel
30
May 30, 2011 10:47 PM
bobbyrjw
22
Jan 30, 2011 08:30 PM
B&LLandscaping
Jan 5, 2006 12:34 AM
