Door question.....
Old Jun 6, 2012 | 08:18 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Door question.....
Anyone know if it's possible to convert 1992+ doors with the cable inside door handle, the older gear driven inside handle?
Old Jun 7, 2012 | 03:54 AM
Spktyr's Avatar
Spktyr
You can swap the physical handle itself. Dunno if the mechanism after the handle can be swapped.
Old Jun 7, 2012 | 04:12 AM
XLT89F350cc's Avatar
XLT89F350cc
Can you just swap whole doors ?
Old Jun 7, 2012 | 04:51 AM
fdude64's Avatar
fdude64
i am gussing your having the same problem i had with the cable fraying and streching. ford wanted like over 100.00 for a new one. since i dont lock my truck i rigged the lock button rod to actuate the door latch. to get out on my driver side you just bump the lock button down and the door opens.
Old Jun 7, 2012 | 04:55 AM
bucks150's Avatar
bucks150
The doors can be swapped ford used the same door design from the early 80s untill 98 in the f-250s and 96 in the f-150s. They changed the body of the f-150 in 97. They only made a few changes and that was the door panels in 87 then they changed the panels, wing glass and went to the cable door latch in 92. And of course the switches changed if you have power windows and locks.
Old Jun 7, 2012 | 09:23 AM
Midnite1987's Avatar
Midnite1987
Why can I picture someone accidentally bumping the button and falling out when driving...lol
Old Jun 7, 2012 | 09:33 AM
SCRebel's Avatar
SCRebel
If I am not mistaking I believe the 95 and 96 F150 doors have an extra bend at the bottom.
Old Jun 7, 2012 | 02:28 PM
IDIDieselJohn
I ask this because I am restoring my 1990 F250 Diesel, and I found near perfect 1994 doors, however I DO NOT want the guts inside the 92+ doors. I wanna keep the gear driven handles from the previous years, much more durable!
Old Jun 7, 2012 | 04:31 PM
jas88's Avatar
jas88
I bet the door frame, the part you attach all the guts to, is the same 80-97.
Old Jun 7, 2012 | 05:28 PM
Spktyr's Avatar
Spktyr
The outer skin panel is different for the 95, that's for sure. And I think there have been some other changes to the skin over the years, too.
Old Jun 7, 2012 | 06:22 PM
IDIDieselJohn
I hope. I'm getting a whole truck saturday. '94 F150 reg. cab short box 4x4 5 speed.
cjben
15
Mar 6, 2022 05:31 PM
papabills54
1978 - 1996 Big Bronco
May 26, 2018 09:13 PM
Roger C
Nov 30, 2015 01:20 PM
hivoltj
Mar 9, 2015 12:05 PM
papabills54
Jan 24, 2014 02:54 PM
