E4OD shift arm locked up
Old Jun 6, 2012 | 07:19 PM
Robbie2618's Avatar
Robbie2618
I have a 93 F150 with the auto E4OD transmission. It will not shift out of drive. I have disconnected the shifter cable from the transmission and the shifter arm on the side of the tranny will not move. What would make the shift arm lock up?
The transmission was acting up right before it happened, when pulling away from a stop the engine would rev to about 2500 rpm before going. Almost felt like it was slipping but then once going it would hold tight with no slipping just woulnt go at low rpms. Then stuck in gear havent been able to move the shift arm no matter how hard I try.
Old Jun 6, 2012 | 08:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The TRS (Transmission Range Sensor) can seize, locking the shift arm, or there could be some debris inside the transmission blocking the manual valve.
Robbie2618
Jun 7, 2012 01:19 AM
masseysbronco
1978 - 1996 Big Bronco
Dec 14, 2011 08:54 PM
airharley
Mar 13, 2002 07:23 AM
