56 Coker Steel Wheel Lug Nuts
I bought Coker Steel Wheels and in anticipation of their arrival, I figured I had better check to make sure I could mount them on my 1956 F-100 drums. There are aftermarket rims with acorns currently on the truck. I had no idea it would be this difficult to find the right lug nuts. I believe to this point that I need open 60 degrees conicals, 1/2 x 20 inch. I ordered the 40's Ford caps and trim rings, also. As far as I know, the drums are stock 4 1/2 BOC studded drums.
Please advise. Once the 15" rims with BF white walls come and I find I haven't the right nuts, I'll probably blow a nut.
Thanks in advance.
Thanks in advance.
Same 1/2" -20 lug nut has been used for decades beginning in 1932, original Ford part number was B-1012, replaced by: B-1012-A, COAZ-1012-A, C9AZ-1012-A, E6DZ-1012-A, now it's: E8AZ-1012-A.
Some applications: 1932/91 misc passenger cars, 1/2 ton commercials, 1948/52 F1/F2/F3, 1953/83 F100, 1966/96 Bronco, 1975/96 F150, 1969/2012 E100/150.
Autoparts stores (prolly local dealers as well) have these puppies, so there's no need to buy from repro parts sellers, then pay shipping charges. Plus, there's gazillions of vehicles in junkyards you can get 'em from.
1977, FoMoCo introduced styled steel & aluminum wheels for F100/150's, E100/150's, Bronco got 'em in 1978. Same chrome or black lug nuts thru 1996. E150's thru today use the same ones.
F150's went to metric wheels in 1997, so these lug nuts are mm's, won't work.
DS02F250
1999 to 2016 Super Duty
12-18-2004 06:29 PM
