Sponsored by: Real Truck
Powerstroke intercooler???
Old May 6, 2003 | 11:51 AM
csmit159's Avatar
csmit159
I don't know if you guys can help, but I figure it's worth a try. I own a 2002 F-250 V10. That's right a V10. I have a Whipple supercharger on it that gives me 6lbs of boost. I'm going to a smaller pulley on the blower so I can get 8-9 pounds of boost. The thing is I don't feel confirtable enough without some sort of intercooler. So my question is, will the Powerstroke intercooler fit in my truck and is it capable of providing the cooler air I need. Any suggestions or advice would be appreciated.
Old May 6, 2003 | 02:53 PM
The Grinch's Avatar
The Grinch
I don't know about fitment, but an intercooler is useful with boost levels over 3-4 lbs. to cool charge air. Search the aftermarket for kits that work with the supercharger you are using then you just have to run the plumbing.
Old May 6, 2003 | 04:47 PM
theologian's Avatar
theologian
Banks has a really good specific intercooler that will fit for you.
Old May 6, 2003 | 10:56 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Same engine bay, so obviously it will fit physically. I have no idea if the radiator/mounts are the same, but if not you could swap out PSD pieces for that too. The V-10 might be longer as well, so you may need electric fans.
I guess my answer to your question is: I have no earthly idea , but as far as
then yes, it is. The '01 and up models have a revised cooler that is larger and flows a bit more.
Old May 7, 2003 | 04:57 AM
csmit159's Avatar
csmit159
Of coarse one of the main reason's I'm interested in the Powerstroke intercooler, is cause I can get one from the dealer for about $320.00(Ford discount). Alot cheaper then an aftermarket intercooler. The only costly thing will be the plumbing. Is it true those turbos on the Powerstroke put out about 12-15 pounds of boost?
Old May 7, 2003 | 06:24 AM
BlueKnight's Avatar
BlueKnight
Can you run an intercooler with that supercharger? Doesn’t it supply the change directly into the top of the intake?? Unlike a turbo that runs off the exhaust flow
Old May 7, 2003 | 07:43 AM
powerstroker250's Avatar
powerstroker250
Stock PSD's produce 17-18psi of boost.
Les
Old May 7, 2003 | 08:06 AM
csmit159's Avatar
csmit159
17-18 pounds of boost? D@mn! Now I'm wondering if that intercooler might actually cause me to lose boost if I use it. This is tougher then I'd thought it would be.
Boostcrazy99
Ford Truck Parts for Sale
Oct 4, 2012 01:24 AM
ttttmaxx
Feb 16, 2010 12:29 PM
Bird Dog
Sep 3, 2007 12:06 PM
powerstroke1869
Aug 26, 2007 07:15 PM
GHOST
Nov 14, 2004 04:27 AM
