Fuel sender unit wiring
Old Jun 5, 2012 | 01:00 PM
alchemist1's Avatar
alchemist1
The damn fool that ripped out the rusted gas tank on my 'new' 74 F-100 also took the filler hose, vent hose, and just found out he clipped the green sending unit wire (so he threw the plug/connector out too). The plug on my new FG73A Spectrum Premium sender looks like two threaded studs. Does anyone know if the OEM plug/connector is made anymore?
Old Jun 5, 2012 | 01:15 PM
CalebJns's Avatar
CalebJns
Yep...you can still get them...Numberdummy may chime in with where you can find one from a Ford Dealer, but you can also order one from LMC...I think it is #7 that you are looking for...
Old Jun 5, 2012 | 01:21 PM
PatientZero's Avatar
PatientZero
yes sir. definitely #7
Old Jun 5, 2012 | 03:19 PM
alchemist1's Avatar
alchemist1
Number Dummy,
would you know the Ford part number for this? thanks
Old Jun 6, 2012 | 06:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Fuel sender wire
D3TZ-14406-B
Bowman Sales and Service, Bowman, ND has 1 (701) 523-3257
Kinsel Lincoln-Mercury, Beaumont, TX has 1 (800) 816-2894
Wesley Obsolete Parts, Liberty, KS has 1 (606) 787-5293
Green Sales, Cincinnati, OH has 5 (800) 543-4959
Old Jun 11, 2012 | 06:51 AM
alchemist1's Avatar
alchemist1
I got an idea. I just got two of the single push on boots from couple of Fords in my salvage yard. I'm gonna solder the connectors onto what is left of my wires (green and ground). the only issue might be if some water gets in between the two connections on the sending unit and 'grounds out' the sending unit. I might stick a dab of non-conducting silicone between the two studs.
Old Jun 11, 2012 | 11:22 AM
PatientZero
As long as they fit over the posts, that should be fine. And anybody feel free to correct me if I'm wrong, but I would think that a dab of dielectric grease ought to do the trick
Old Jun 17, 2012 | 03:32 PM
alchemist1's Avatar
alchemist1
thanks. I'm going to use some basic silicone caulking. Dielectric grease won't 'cure', but that caulk will cure / harden. Hoping the acetic acid in there won't rust the 'gold plated' studs.
BBrown1017
13
Jun 15, 2018 11:24 AM
Christopher Workman
Apr 12, 2018 01:29 PM
cabloom300
Oct 1, 2013 07:16 PM
Anafiel
1978 - 1996 Big Bronco
Feb 28, 2011 05:02 PM
66crawler
Aug 14, 2010 07:48 PM
