F250 upgrade time
Old Jun 5, 2012 | 12:41 PM
Lmkonzen's Avatar
Lmkonzen
F250 upgrade time
Hi guys. I have a 1996 F250 7.5L v8 XLT. I've finally gotten some money saved up and I want to invest in some upgrades. I've already taken care of the sound system, and the lift kit/tires. My next adventure is the exhaust. I am removing the cat. due to having smog exempt paperwork and I want to put the muffler on right where the cat used to be and put a tip that dumps the exhaust right out the side behind the passengers door. Any ideas and what muffler I should get? I want to make my truck louder and deeper but not have annoying interior resonance. Any help is appreciated. Thanks.
Old Jun 5, 2012 | 01:36 PM
White 97 xlt's Avatar
White 97 xlt
Those two requirements are NOT going to work well with each other!!!
Old Jun 5, 2012 | 02:09 PM
Lmkonzen's Avatar
Lmkonzen
Well as long as it isn't deafening inside I'm ok with it. And I'm just curious what style of muffler works the best for these trucks
Old Jun 5, 2012 | 02:51 PM
Lmkonzen's Avatar
Lmkonzen
And when I say under the passengers door I mean farther back under the bed. It's an extended cab long bed. I will probably have the tip poke out about a foot or so from the rear tire.
Old Jun 5, 2012 | 03:16 PM
RIKIL's Avatar
RIKIL
Flowmaster 30 or 40 series sounds like what you want.
Old Jun 5, 2012 | 03:22 PM
Lmkonzen's Avatar
Lmkonzen
What do you think about the 44? And do you know what size the pipe is? 2.25 or 2.5 or 3"?
Old Jun 5, 2012 | 03:34 PM
RIKIL's Avatar
RIKIL
I want to say the pipe is 2.5" but could be 2.25", it's not 3". You can get the flowmaster in any size from what I remember.
As for the 44, the higher number you go, the quieter the muffler will be. Check out flowmaster site, they have good info.
Old Jun 5, 2012 | 03:37 PM
Lmkonzen's Avatar
Lmkonzen
All right. Thank you. Do you have any recommendations for the tip sizes?
Old Jun 5, 2012 | 03:53 PM
RIKIL's Avatar
RIKIL
No use in getting a special tip. If you get anything with a coating, it will just be eroded off by the rocks from the road. I just have them baloney cut some of the same size pipe and put it on there.
husky390
Feb 16, 2013 08:21 PM
spike552
Jul 13, 2008 05:19 PM
bruno6491
Feb 16, 2008 12:21 PM
02Ford150
Exhaust Systems
Jan 26, 2007 05:40 PM
seebeew
Exhaust Systems
Oct 2, 2002 01:14 AM
