Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
20003 Escape HELP!!!
Old Jun 5, 2012 | 10:34 AM
BoB111's Avatar
BoB111
I have an 03 Escape that I just replaced the battery and the alternator. Drove it and everything seemed fine until it died again. Driving and all of the sudden it just gave out no battery light or anything came on. towed it home and tried to jump it to get the windows up but it wont do anything. the interior lights keep blinking while hooked up to the other car until you turn the key then they go off. Starter or a bad ground maybe? Any suggestions would be appreciated so it can go get traded in as its been the vehicle from hell!!
Old Jun 5, 2012 | 11:07 AM
redmaro42's Avatar
redmaro42
battery terminals are tight and making good connection?
Old Jun 5, 2012 | 03:31 PM
BoB111's Avatar
BoB111
yes and i just got back from having the starter tested and it was good. The battery that was just put in there is shot now too. I'm thinking that the alternator is shot once again.
Old Jun 5, 2012 | 06:24 PM
tcesni's Avatar
tcesni
Aftermarket alternators are often of poor quality. I went through three before I got one that lasted more than a week.
Old Jun 6, 2012 | 08:17 AM
tomw's Avatar
tomw
Batteries can short out in an instant, be good at 1:00, and be junk by 1:10. Had it happen, and just didn't believe that it could start the engine, be normal, and then ten minutes later be so shot it took an wrecker mounted, self-powered jumper to kick it over enough to get home. Jumper cables wouldn't do it. That can have an effect on an alternator, and the internal regulator, putting an extreme load on both.
I would also be looking at the electrical panel next to the battery under the hood. A battery that was overcharging due to a bad cell can emit a lot of acid, and cause corrosive damage. A good wash with a baking soda solution and neutralize the acid. If soda/water bubbles when you wet the surface, there's acid there.
tom
seths89f150
15
Feb 24, 2011 05:51 AM
plumberglen
1997 - 2003 F150
Jan 6, 2011 06:42 PM
jaspirr
May 12, 2009 10:01 PM
mtj922
1983 - 2012 Ranger & B-Series
Apr 5, 2005 10:03 PM
ucmeflyby
1978 - 1996 Big Bronco
Oct 5, 2003 04:58 PM
