1997 4X4 Engagement Problems
Old Jan 10, 2014 | 10:58 AM
TyBragg's Avatar
TyBragg
If you plan on taking off the linkage bar, you have to be very careful when taking it off because you will break the studs that it fits on very easily. Your first inclination is to use a pry bar or something to get it to pop off the studs. That will work, but we've broken the studs trying to do that. Then you're worse off. We use a small bearing/gear puller to get them off there - you can take the two arms and hook on the linkage bar and pull it right off the stud. Never broken one like that.
Sweeneylandscape
Feb 15, 2015 07:05 PM
dougielx
Aerostar
Sep 22, 2008 03:23 PM
cooploops
Oct 27, 2007 02:43 PM
gbrett
Dec 11, 2006 06:40 PM
