fuel pump question
Old Jun 4, 2012 | 11:39 PM
1964Goat's Avatar
1964Goat
fuel pump question
Okay so ive got a 1964 straight 6 262 and need a fuel pump but i can only fine a fuel pump for a 223 on lmc here LMC Truck Parts - Page 50 can anyone help me out does it matter the engine size?
Old Jun 5, 2012 | 05:54 AM
jowilker's Avatar
jowilker
Have you tried your local parts houses. You should be able to get one there.
John
Old Jun 5, 2012 | 06:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1964Goat
I've got a 1964 straight 6 262 and need a fuel pump, but I can only find a fuel pump for a 223 on lmc here LMC Truck Parts - Page 50 can anyone help me out does it matter the engine size?
C4TZ-9350-B .. Fuel Pump / Obsolete / All 1964 262 I-6 trucks only / 223 is not the same / 1961/63 262 is not the same.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
FREESE MOTORS in Monticello IA has ONE = 319-465-3541.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
C4TZ-9349-A .. Fuel Pump Repair Kit / Obsolete / All 1964 262 I-6 trucks only.
GREEN SALES CO. has ONE.
Old Jun 5, 2012 | 07:34 AM
gottahaveaford's Avatar
gottahaveaford
NumberDummy already stated that its not the same as the 223 which is what I have. But, when mine went I was able to get a fuel pump from NAPA. You should check there even though yours is a little more rare.
Old Jun 5, 2012 | 12:45 PM
1972RedNeck's Avatar
1972RedNeck
I had the same problem with our '64. Napa couldn't get one. I ended up swapping the diaphragm from an FE pump.
Old Jun 5, 2012 | 03:24 PM
charliemccraney's Avatar
charliemccraney
Is there anything that will work? For instance, FE pumps will work in a Y-Block. Is there another pump that will work in a 262 even though it's not correct and may not cross reference?
Old Jun 5, 2012 | 04:13 PM
NumberDummy
Originally Posted by med-care-guy
hey guys first timer usually i fuiger tings out myself but im stumped my fuel pump has no power all fuses good cut of switch good still cant find relay for sum reason and i need to get this ambulance back up. any help would by helpfull at this point dnt knw much about ford trynna change that. all my fleet is ford 28 trucks.
Welcome to FTE
I asked a moderator to move your thread to the correct forum. This one is for 1961/66 trucks, so you won't get much help here.
Old Jun 5, 2012 | 04:15 PM
NumberDummy
1964 262 I-6 fuel pump/fuel pump repair kit is one year only, nothing else is the same. Post #3, found the OP 5 NOS fuel pumps, 1 NOS fuel pump repair kit.
Old Jun 5, 2012 | 07:54 PM
1972RedNeck
Very good info for a later date.
Old Jun 6, 2012 | 01:49 AM
NumberDummy
1963/64 F100/350 292 uses the exact same fuel pump as 1965/67 F100/350 352, 1968/76 F100/350 360/390 / 1963/71 Galaxie/LTD 352/390.
As original: The 1961/62 292 fuel pumps had a glass bowl with a ceramic filter inside. 1963/64 292's and the FE's have a metal can that threads on with a cartridge fuel filter inside.
D2TZ-9350-A fuel pump replaced: C3AZ-9350-J (292), C3AZ-9350-R & S (FE car/truck), C9TZ-9350-A (truck).
And, FT engines also use this same fuel pump.
patrick 64
Aug 12, 2012 09:41 PM
danhoward
Jun 1, 2010 06:37 PM
oldsenile
Mar 16, 2007 08:25 PM
jhooch
Jul 3, 2006 03:26 AM
