Flatbed
Old Jun 3, 2012 | 12:26 PM
cvilleOUTLAW's Avatar
cvilleOUTLAW
Flatbed
thinking about putting on a flatbed.
any advice or pointers? i really dont know anything about this but my current bed is completely rusted out and one of the bed side rails is on the verge of falling off.
Old Jun 3, 2012 | 03:50 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Most are made of either steel frame with wood plank inlay (cheaper and light), or a all steel and tread plate VERY heavy or a all aluminium (VERY EXPENSIVE) but lighter than the all steel option.
Can be bought fairly cheap where I live, go out in the country side and ck around some tractor supply or dealerships that do a chassis only and then offer a flat bed install option. Find out where they get there's or ask around the local feed store.....
You can get a all steel HD headache rack and under bed storage boxes, usually in front of the axle and one on each side. Sometimes it takes a little modifying to get the filler neck to work but its manageable.
Most are universal in size and are some what a bolt on deal for newer trucks. Almost any welding shop can attach the brackets to make it a bolt on deal for our older rigs.
The bottom pic is the top pic bed after it was taken off, and I want at least least 5 to 8 HUNDRED FOR IT. Cause its like new and has the cover plate for the gooseneck trailer ball.
Bottom deal I GET CHEAPER INSURSANCE WITH A FLAT BED AND FARM TAGS.
Old Jun 3, 2012 | 06:46 PM
customrich&matt's Avatar
customrich&matt
dont go alum too lite no traction
Old Jun 3, 2012 | 08:20 PM
hasteranger's Avatar
hasteranger
my flatbed is at least 1/4 thick steel, and it might even be 5/16's. It has heavy pipe border in 2 crossmembers, the front and back, and the sides, and a giant headache rack. It is thick as ****. The good: I can haul whatever I want. want to drop a 351m scrap motor onto it from a hoist? whatever. Want to back over a tree? it'll do it.
the bad? the damn bed weighs like 600 lbs. Its way overbuilt for a 1/2 ton truck.
Plus mine has box tubs they welded in for skinny *** tires, and they don't work at all with pretty much any tire. I even have a set of stock 15's with like 29 or 30" tires on them and they rub the outside of the box. Hopefully they won't rub after my lift is on, or I'll have to cut up the bed and either make larger tubs or more likely just raise the edges up like the 5th bed down in that row of pics.
IcutMetl
May 21, 2013 02:21 PM
tealboy1
Nov 7, 2005 09:06 AM
fordmtnman
Paint & Bodywork
16
Jul 8, 2005 01:52 PM
67red
Dec 13, 2004 12:19 PM
Dogmaster
1997 - 2003 F150
Oct 5, 2003 06:36 PM
