Rusted out bed, suggestions?
My hunting camp truck bed has finally deteriorated to the point that i need to do something. It is a 76 f150 4x4. I want to be able to load my atv into the back on occassion to transport it on the hunting lease, never the highway. I considered laying a 3/4 inch piece of plywood in the back, replacing the entire bed (perhaps too expensive and too much work) or welding a sheet of steel to provide the strength i need.
basically, the bed has opened up around the cab area. there are several large holes.
any suggestions on what to do?
I second (or is it third?) the idea of a wooden bed. That's easy
to build, very customizable, and you can replace any parts that
get damaged. Haven't done this myself but would try using a
4x6 box structure, bolt that to the frame, use 2x6s for the bed,
use 2x4s for the uprights, and maybe use 1x6s for the sides.
Use screws for the siding so you can unbolt them and take
them off when you just want a flat-bed. Should work pretty
well but you might want to lay this out on paper and try a few
mods before getting down to business. Using pressure treated
wood sounds like a great idea to me, especially if you live in a
wet climate.
wet climate.
That would work great for strength but I would be concerned about water trapped between the diamond plate and the bed. Even if you can't see it, rust will still be working on the bed and perhaps also on the frame. Did they tack weld the diamond plate in place or seal it all around somehow? Sealing would be good and a good grade of outdoor silicone caulk might work for this.
I would buy a wreck donor bed (it doesn't have to be perfect and cut our sections to replace. If you (or have it done should cost much), place tack welds on opposite sides of the patch with a MIG and keep tacking back and forth, slightly overlapping the tacks, the metal won't warp. It will be strong and look good. Sorry, guys, but everytime I try to weld wood, it catches on fire. Metal for me!
Big IV
22
05-11-2010 01:49 PM
