1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Alignment today
Old 06-03-2012, 01:15 AM
jc8825's Avatar
jc8825
jc8825 is offline
Alignment today
I have had a minor alignment issue for a while, and even though I had an alignment done about 3 months ago, I had an alignment done today. My Camber before was -.1 on each side and the Toe was -.01 on the right. They aligned those two to 0 Camber each side and .05 Toe each side, but my Caster was unchanged at 2.7 on the left and 3.1 on the right. I thought I read that the Caster should be corrected as well. Please educate me.
Old 06-03-2012, 07:04 AM
jmahle67's Avatar
jmahle67
jmahle67 is offline
Most shops don't adjust caster because its not usually an adjustment they can make. It usually involves buying shims or eccentrics or something of Thar nature
Old 06-03-2012, 07:38 AM
DieselVol's Avatar
DieselVol
DieselVol is offline
Find out where the body shops in your area take repaired cars for realignment. They will have a man who knows how to get it done right. Yes, he will use shems, but as long it's aligned, who cares? I had to buy a $130 shem kit when they aligned my front after I added a leveling kit, but the savings on tires will make up for it.
Old 06-04-2012, 06:21 PM
a12play12's Avatar
a12play12
a12play12 is offline
Many shops leave caster .5 degrees positive on the right to compensate for road crown. Caster is NOT a tire wearing angle. Depending on road crown and surface in your area, you may get a pull to the right if camber is set equal left and right.
jeffreyclay
08-13-2016 10:04 PM
rustyleerusk
06-26-2014 11:30 PM
wildcat99
2004 - 2008 F150
04-09-2009 01:35 PM
papa's 64
1983 - 2012 Ranger & B-Series
04-12-2005 09:34 AM
cw50must
Arizona Chapter
09-07-2002 09:51 AM
Quick Reply: Alignment today
