Update: How its going so-far EGR/Oil coolers(with many pics)
#48
Rusty that IAT sensor in your Picture is Number 2 In the Intake manafold
IAT1 is the one right after the Air Cleaner
PCM uses IAT2 to see your EGR Valve open and close verifys the flow by temp change
Looks Great I take my time to I dont do that stuff enough to rush it I forget stuff or throw something on ahead of something else never fails either
#49
Looks DARN good Rusty.. I started on my tear down and will try to post (play catch up) tonight or maybe this weekend with the thread "Part 2" Tear down... I have a question for you and anyone else that is reading. I bought the International STC upgrade kits and it doesn’t contain the Install tool/bracket (plastic bracket and fasteners). I was wondering if you still had yours and if so would you be willing to US mail it to me?? I'd send it back with some cash to cover your shipping cost. I have already opened the kit so I can’t return it. another quest question.. You keep referencing Aircraft.. Do you work for an aircraft company? I'll just note that I do. I'm an engineer and live in the Seattle area so you should be able to figure out for who. fficeffice" /><O></O>
It looks real good Rusty. I can appreciate taking your time to do it right as its the main reason I am doing mine myself.. I want it done right and right! and right IMAO is just like what you’re doing!!<O></O>
Dirk
Dirk
#50
#51
Dirk
Dirk
andriven2liv,
I was gonna paint that valley and make it a real "thing of beauty" but I decided to leave the factory markings.
#52
#54
Thanks for the encouragement guys! I hope fire this thing up Sunday. I'm going to pour two or three quarts of oil through the filter housing iirc that will fill up the HPOP resivour (<--spelling?). I'll have the batteries topped off on the charger, and cycle the key 3-4 times to fill the upper fuel filter before cranking it. Anything else I can do to get it up and running? Should I just let it idle for awhile or drive it right away (after it warms up a little)?
Dirk,
Package is in the mail. Check your e-mail also.
Dirk,
#55
It will take a lot of cranking before it'll fire. I did 20 seconds cranking, 2 min cool down and repeated. I think it fired up on the 3rd 20 second cranking period. Let it idle for a while, I kicked mine up on high idle and did a coolant flush before driving. Even after several hours of high idle and a couple short trips, I think it still had a little air in the HP oil system, so don't be surprised if you still have a few long-ish cranks after it's up and running.
#56
I think you have to leave the standpipe out for that to work, if you just pour it into the housing with the filter removed it'll just drain back to the pan.
#57
#58
#60
Do you guys think some of that plastic sheathing stuff would be worth the trouble on the wiring harnesses? They are pretty gnarly and sticky from the factory tape. I guess I could just re-wrap them but the factory tape looks like pretty good stuff and I don't know if I can find anything like that on a weekend.
