Pickup not starting
Old Jun 2, 2012 | 05:43 PM
Bovaloe's Avatar
Bovaloe
Pickup not starting
1988 F150, 5.0, 2wd, Auto
Drove it to work yesterday, CE light came on, stumbled at a stop light, then started idling high, about 1400, pulled into work, popped the hood, pulled off the connector to the IAC, it dies. Plug it back in and start it back up just fine, still idles high.
Couple hours later I go to drive it home to plug in my code reader, now it won't start. Grabbed the work rig and went home to grab my code reader, plug it in and nothing, wont connect. I work at Autozone so I grabbed the one we have on the shelf, has a flashing light and beeps, it just constantly beeps when you plug it in, so I think the diagnostic connector is busted.
Also both pumps are running all the time when the key in on, they don't shut off.
I have tested the pressure at the rail and have 40 psi.
I am getting spark. Tried a new fuel pump relay, same.
Could my ECU just up and puke like that? What else controls the pumps and the fuel injector pulses?
Any ideas?
Old Jun 2, 2012 | 05:57 PM
DRRXR's Avatar
DRRXR
Well since you tried a new pump relay I would say the ECU relay is closed or you have a ingnition switch issue.
Is the old pump relay still in there?
Old Jun 2, 2012 | 06:43 PM
Bovaloe's Avatar
Bovaloe
Yup, pulled a new one and threw it in, didn't change so I put the old one back in.
Is the ECU relay the one right next to the fuel pump relay? I plugged the new relay into both and no change. Which is which? There are green and brown connectors
Old Jun 2, 2012 | 08:42 PM
Lead Head's Avatar
Lead Head
Is the check engine light on when you turn the key on? Sounds like you may have had an ECU failure. Some of these Ford computers run into capacitor issues as they age.
Old Jun 2, 2012 | 08:59 PM
Bovaloe's Avatar
Bovaloe
Yeah its on.
Did anything change from 88 to 91? I have an ECU from my other pickup when I swapped it to MAF. Is the AOD from 88 computer controlled? The ECU is out of a manual
Old Jun 2, 2012 | 09:03 PM
subford's Avatar
subford
Sounds like the clock stopped in the computer. Some have replaced the crystal to get the computers clock running again.
The clock has to run to get the fuel pumps to time out and stop after one second and you also need the clock to fire the injectors.
The fuel pump will not run if the EEC power relay is bad.
No an AOD is not computer controlled.
Old Jun 3, 2012 | 12:30 PM
Bovaloe's Avatar
Bovaloe
Well, I threw the ecu from my 91 from when I did the MAF swap, pickup fired right up like normal. Good thing I don't throw anything out. Problem solved
Old Jun 3, 2012 | 02:06 PM
DRRXR's Avatar
DRRXR
Good for you. Now what?
spurredon
23
Mar 15, 2010 12:37 PM
SeannyBoy84
Modular V8 (4.6L, 5.4L)
Jul 1, 2009 08:31 PM
ekincaid_f150
Apr 22, 2005 10:51 PM
jamesmonty
Jun 23, 2003 12:07 PM
lurch
1978 - 1996 Big Bronco
Sep 4, 2002 10:44 AM
