Sponsored by: Auxito
whining noise
Old Jun 2, 2012 | 03:04 PM
94powerstroke's Avatar
94powerstroke
whining noise
hi guys i just purchased an 01 supercrew the other day and it has like a poersteering whining noise to it. today i went out and replaced the power steering pump and it still making thr whining noise any ideas what it could be ? the steering is nice and solid no excessive play or anything. i have noticed in the resevoir bottle at idle the fluid is splashing around in their should it be doing that or is their some sort of pressure sensor someplace acting up?
Old Jun 2, 2012 | 04:48 PM
critterf1's Avatar
critterf1
Does it get louder or change pitch when turning the wheel?
Old Jun 2, 2012 | 05:06 PM
94powerstroke
no dosent get any louder when turning the whee;s and while driving it seems like it goes away or you just dont hear it only seems to be at idle.
Old Jun 2, 2012 | 09:40 PM
steve(ill)'s Avatar
steve(ill)
If only at idle, might be related to EGR / vacuum / PCV valve... etc
Old Jun 3, 2012 | 07:53 AM
coolguy1419's Avatar
coolguy1419
Check your idler and tensioner pulleys on the belt. I had the same problem on my 03 when I got it. Changed the power steering pump and was still there! Turned out to be the bearings shot on the tensioner pulley. Stand right over the tensioner puller and then give it alittle gas. It will make a little higher squeel then go to a constant squeel if it is that. Good luck
Old Jun 4, 2012 | 02:58 PM
94powerstroke
changed my belt tensioner and idler pulley to day and sure enough the bearings were worn out in both pulleys thanks for te advice.
nicholas116
2004 - 2008 F150
Dec 28, 2016 07:15 PM
chuck2629
2004 - 2008 F150
Nov 9, 2015 07:13 PM
riverratmike
Modular V10 (6.8l)
Dec 5, 2009 06:02 AM
mhanson156
Dec 30, 2004 07:58 PM
moorejason
1997 - 2003 F150
Sep 20, 2002 12:23 PM
