PHP & Banks Transcommand
Old Jun 15, 2012 | 12:59 PM
bleeds blue's Avatar
bleeds blue
Oh stage 1's are on the list. I'm going to do the e fuel from beans first. That is if they will ever call me back.
Sick of all the little diesel leaks. Seems like they never end!
Old Jun 15, 2012 | 08:58 PM
oldbird1965's Avatar
oldbird1965
That's why I did my e fuel!
Old Jun 15, 2012 | 09:24 PM
rodneywar's Avatar
rodneywar
same here! but i revised beans system since the brass fittings didn't jive with me and caused me to crack a head trying to remove a broken brass fitting that broke off inside the head i went with -an fittings all around steel is better anyways
Old Jun 15, 2012 | 09:29 PM
Talyn's Avatar
Talyn
1200 for beans kit, or you can buy the parts yourself for 500-600.
Your choice.
Old Jun 15, 2012 | 09:36 PM
rodneywar's Avatar
rodneywar
it is on sale rite now 850 bucks free shipping
Old Jun 15, 2012 | 11:30 PM
oldbird1965
That must have been a nightmare!! Did you have to replace the head? If it was cracked, I suppose you did.
Old Jun 15, 2012 | 11:42 PM
bleeds blue
Ordered the beans kit earlier. Hopefully the best $850 I ever spent!!
Old Jun 15, 2012 | 11:44 PM
ReBilld's Avatar
ReBilld
Take lots of pics of the install!
Old Jun 16, 2012 | 08:15 AM
Talyn's Avatar
Talyn
The beans kit from what I seen on Neals truck is not that bad.
Old Jun 16, 2012 | 08:53 AM
rodneywar's Avatar
rodneywar
yep replaced the head i was pissed the corner of the head is thin and broke off no way to fix it after i did it i went to a hydraulic shop got a couple fittings it worked like a charm and easy removal for service if the need arises i will post it is a great kit everything went as it should but the fitting in the back of the heads need to be redesigned by beans or they should follow what i did to prevent this from happening i have clearance between the head in collector where i didn't have much with the brass fittings i did grind the collector down a bit to achieve 1/4 inch of clearance not much tho
Old Jun 16, 2012 | 10:06 AM
bleeds blue
Ronnie, you have any pics?
Old Jun 17, 2012 | 10:00 AM
rodneywar's Avatar
rodneywar
of what the head being broke or the fittings
Joe_D
May 7, 2008 03:52 PM
Joe_D
May 4, 2008 10:44 AM
444dieselrod
Mar 5, 2005 09:51 AM
fishbiodad
Apr 16, 2004 09:38 PM
