Ford engineers, how difficult is this?
I just fly by the seat of my pants, and odo, fuel guage! LOL.
I know my fuel guage goes down faster when I tow, and when I'm not towing, it doesn't go down as fast.
Good luck on Your recalibration!
I also still do not believe that changing the DTE setting will impact the accuracy of the history stored - as according to the manual all that is being changed is the "calculation method" for the DTE number. Therefore I don't think there is a need to change the setting every time to establish an accurate history. If it was, then this would be even more of a flaw.
Hey, this really is not a big deal, it just seems to be a sloppy implementation. As an electrical engineer, I can see how easy it would be to do this right, and report numbers that make sense. Maybe we are all missing something - but if that is the case, then the manual is incomplete or even inaccurate.
I can see both sides to this. Your point is it should automatically calculate using the numbers from every time you have towed. I believe the others are correct though, that you have to manually set it to "flag" those miles as towing to be used in the future DTE calcs. The advantage of that would be for people who tow many weights and some empty trailers. They would only set it for "towing" when towing close to their normal max or heavy loads. Those are the ones that affect it the most and would give you the most accurate history to use each time (when hauling heavy). The best option would be several tow settings (light, med, heavy) and would give the most acccurate DTE figures. Or let the truck figure how heavy the tow is and figure accordingly.
. Don't worry about how someone else would connect their trailer to it. These truck are made for everyone to use and are versital in what features get used and how they are used per individual.
so if you were towing with the tow/haul "off" it would assume "not towing" and would screw up your DTE algorithims.
maybe i made it up ... but i SWEAR i read that somwhere ....
I don't think you understood what I have said.If they can't distinguish if somebody with a 4 pin plug is towing, then why disable the correct history for everybody?
Maybe I misunderstand you, Kevin, but it does not make much sense to me what you are saying. I am very sure also that most people tow with a 7 connector plug.
So because you (or somebody else) does not have a 12V accessory, none of the 12V accessories in any truck should work?
If they would have enabled correct mpg calculations for people with a 7 way plug connector (most people), that would have had no negative effect on those few towing with a 4 pin connector, they just would not have that feature.
I am not sure how to manually set it and tell the truck I want towing fuel consumption to be stored, it may still do that automatically, don't know. The DTE setting, according to the manual, only changes how DTE is calculated, and not how fuel consumption is stored or recorded. It would be great to find out though how it really works - I think we are all guessing. Next time I am towing (this coming weekend), I will set it to DTE and see what happens.
It looks like I am not the only one who is puzzled about this
:https://www.ford-trucks.com/forums/1...culations.html
http://www.f150forum.com/f38/dte-cal...oblems-138468/
And here is one more, so I am not alone. This guy sees the same weird behavior I do: that with "towing history" used, my DTE gets higher, LOL:
http://www.f150forum.com/f38/dte-cal...ystery-107892/
I do think that this feature is somewhat messed up once towing gets into the equation.
perhaps, in order to get back to square, it might be quicker to reset it back to the default and let the truck relearn.
i guess the one thing to take away from this thread for sure is that if you like to use the DTE display, you had better make sure you switch from "towing" to "normal" depending on what you are doing with the truck.
as far as it being tied into the tow/haul mode, i must have dreamed it because i could not find any reference to it in the manual what-so-ever.
since this is directed at ford (somewhat) .... why not as the driver which trailer he is towing when you depress the tow/haul? one would think that if the driver presses the tow/haul, that he is either towing or hauling.
then, based on which trailer you are towing, it could calculate a more accurate DTE for each individual trailer. This would be UBER handy for a guy like me who might tow any one of 5 trailers. the boat pulls different than the utility trailer which pulls different than the horse trailer, which is different than the car trailer...... since you can name each trailer, and remember trailer brake settings for each, why not store a DTE algorithm for each? while we are at it, lets have one for "hauling" too, since it is labled "tow/haul"
are you reading, ford?
this falls under the same category as "neutral tow" and an elocker that works in 2wd ... both no-brainers that took about 3 model years to ford to come out with.....
its late .... sorry ... but seriously, why are these things so easy for me to see and yet it takes them forever to figgure it out and get it on the market?
