95 Powerstroke brake problem
Old Jun 1, 2012 | 04:52 PM
49F1BIGBLOCK's Avatar
49F1BIGBLOCK
I have a 95 F250 psd that started out as a gas truck. I thought the vacuum pump was bad. I had a real good pedal and stop the first time I would hit it then it was like there was no vacuum (hard pedal ) but if I would give it a few seconds I would have a good pedal again. I changed the pump today and still had the same problem so I changed the booster from the parts truck and now the pedal is hard all the time. I drove both trucks before and both had good brakes. The pump is pulling good vacuum now. Any ideas ?
Old Jun 1, 2012 | 05:16 PM
madpogue's Avatar
madpogue
Do the HVAC controls all work okay?
Old Jun 1, 2012 | 06:02 PM
j250hd's Avatar
j250hd
Sorry to hijack! What is the cause if the vent controls take a minute to switch from blowing out the defrost to the vents? Also I have a soft brake pedal.
Old Jun 1, 2012 | 06:52 PM
Action4478's Avatar
Action4478
Did you change the check valve too ..?
Old Jun 1, 2012 | 07:52 PM
49F1BIGBLOCK
I had not thought about the hvac controls but they are stuck on defrost. I dont seem to have much vacuum to tho line for the controls. I decided to try running the line from the pump to the booster and took it for a ride. The pedal is usually hard at first then starts to soften up and work ok until I let up on it. Sometimes I get a good pedal as soon as I hit it. I am almost positive the check valve is the one off the psd truck
Old Jun 2, 2012 | 03:29 AM
Spktyr's Avatar
Spktyr
Should post this in your own thread, but typically that's an indicator of a vacuum leak somewhere. Also, there's supposed to be a 'zero leak' vacuum booster that fixes the somewhat soft pedal that these trucks came with from the factory.
Old Jun 2, 2012 | 11:19 AM
madpogue's Avatar
madpogue
"Zero loss" is the actual buzz-phrase for it.
NM_91IDI
19
Jan 3, 2016 06:09 AM
stainlessstroker95
Oct 24, 2012 05:35 PM
damac
Jan 22, 2010 09:29 AM
wildstang
Feb 4, 2009 01:54 PM
wobndob
Aerostar
Dec 30, 2004 02:06 PM
