1949 F3 Transmission Options
Hi
My 4 speed non synchro is a little worn with large sections missing to the spur gears. Rather than looking for rebuild parts I was considering options for a synchro box.
Now I know there are loads of links on here about this very topic but none seem to be definitive as to what the options are in terms of straight bolt in, mods needed, parts availability, etc. it's looks like a T98 silent synchro from an F6 would be the most straight forward replacement but I imagine these boxes are hard to come by, what are rebuild kits / parts like for these?
If anyone has successfully replaced their crash box in an F3 for a synchro and can let me know the issues, mods, all products out there needed to finish job that would be real helpful. If I'm going to swap out the transmission I want a good clear understanding of what I'm in for!
Thanks in advance.
Andrew
Thanks in advance.
Andrew
I will tell you what route I took , but considering your location any thing is going to be costly (shipping cost) . I chose to use a Borg-Warner T5 5speed overdrive box with an adaptor plate from Macs antique auto parts . Solves two problems at once syncro transmission and improves final drive ratio . Just my solution ,there are others .
The cleanest no drama swap would be the 3HD that was optional on the F-2s and F-3s. Should be a bolt in swap. They are synchro on 2nd and 3rd, which is really all you need. Finding one might be an another issue though. I'd love to find one too. Other than that I don't know much else about them. Stu
Thanks guys.
On the T5 conversion:
- what year box did you use?
- Does the box go onto the original hogs head with the adapter you mention?
- Presumably it needed the rear mount relocating?
- Did the shifter need some adjustment so it didn't hit the seat?
- how did you deal with the driveshaft and main drive?
Sorry for all the questions but if im going to go this route i want to be sure i know what i'm in for as being in the uk parts will be a slight issue. Have you got any photos of your install oldmerc?
Thanks
Thanks
Hi Andrew
I just realized that you're not a million miles from me, about 8 in fact. My 1949 F2 is completely stock apart from the transmission that the PO installed. It's an NP435 as fitted to later Ford and other pickups and has synchro on 2nd to 4th and retains the granny 1st gear. There is a thick adaptor plate and the trans mount has been move rearward and the driveshaft was shortened. It works really well so if you want to try it or cross reference any F2 to F3 parts, let me know.
Speaking of Chuck's trucks, I've just ordered his 4.11 diff conversion kit to raise the gearing.
Cheers.
Bob
Cheers.
Bob
Hi Bob
How strange, two old F series shipped all that way and end up only a few miles apart! Where was yours from? Mine was from Nebraska.
I bought a rebuilt F4/6 synco 4 speed trans from chuck (still granny 1st gear). It was pretty much a bolt straight in which was great as I didn't want to cut the truck up. It just need a slightly shortened drive shaft which wasn't a problem as the original was badly bent so Bailey Morris in St Neots made me one up, it used a different yoke too.
Whilst on this I too got one of the 4.11 ring and pinions from chuck, makes the top end much better. Was an excuse to overhaul the rear axle at the same time!
My F3 is pretty stock, the only mods I made whilst I restored it were a 3" dropped front beam using an original donor I beam and I took a few leafs out on the back. I just prefer it to sit slightly lower.
This truck was the start of my American car / truck addiction and I now have many 40's 50's and 60's imports.
Where are you based?
Andrew
Andrew
Andrew
Yes, small world eh! I'm at West Deeping, just the other side of Stamford, so if you're going past pop in.
My truck was from North Dakota, then spent several years on display in an appliance store, then a restaurant in Duluth before being imported in 2004.
I'm glad you got your transmission sorted and surprised you've already installed Chuck's 4.11 conversion kit. I started a thread on this conversion and I wonder if you mind going on it and describing how the installation went because I, along with other members, am very interested in how easy or difficult it was.
Wow, you're collection sounds great. What other US vehicles have you got?
Bob
Bob
LilJayV10
07-02-2013 11:14 PM
