Sponsored by: Kumho
Fuggy Steering ?
Old Aug 30, 2008 | 01:39 PM
suzuki1750's Avatar
suzuki1750
Fuggy Steering ?
I think i am going to do a high steer d60 crossover setup on the buggy. What box would be a good candidate for this setup? I am thinking outside frame rail box. Any info would be great
Thanks
Old Aug 31, 2008 | 01:42 AM
75F350's Avatar
75F350
Do you have any objections to the compact, and easy to install 2wd saginaw?
Image of saginaw power steering conversion - Photobucket - Video and Image Hosting
These are easy as pie to obtain, cheap as can be, offered in as many gear ratios that can be desired, and the aftermarket support is second to none.
I think some grocery stores are stocking parts for these, and you may even find complete units in the produce isle, these things are so common.
Really, the nice, and conveniant part about this box, is when your are on the trail, and need a seal or something. Could almost guarantee that you will find anything you need in a camp nearby. Try doing that with anything else.
I try to carry plenty of parts myself, but sometimes the entire box has to be replaced, and this box is so common, you might find one growing wild on the side of the road.
Old Aug 31, 2008 | 09:39 AM
suzuki1750's Avatar
suzuki1750
what vehicle would be a good candidate for this box? Can they be tapped for hydraulic assist?
