Help decode my codes
Old Jun 1, 2012 | 01:03 PM
jurban's Avatar
jurban
I have an 89 f150, 300 6 cyl and manual 5 speed. I installed the jumper wire in the diagnostic ports, and the light flashed 6 times paused then 7 times, paused then 6 times, and then 7 times again. after a longer pause it flashed 1,1,4,3,1,4,1,8,7,9,6. Thats alot of codes. after this I did the engine running test, it flashed 3 times (6 cyl) I cranked the steering wheel and then returned it, I saw no flash telling me to press the accelerator and no codes were displayed after that. any ideas?
Old Jun 5, 2012 | 05:08 AM
EPNCSU2006's Avatar
EPNCSU2006
Is it a manual transmission? If so, for some reason the six cylinder trucks require you to hold the clutch on the floor while running the tests. Looks like you have code 67 (I think related to the clutch switch), 14, 31, 41, 87, and 96.
1992FordF150Custom
Jun 20, 2014 07:24 AM
TOPPENTECH
Apr 1, 2014 10:10 PM
jurban
Jun 1, 2012 01:23 PM
IHUNT
Dec 8, 2004 12:02 PM
cryptonik420
May 5, 2004 08:32 PM
