windshield interchangability between excursion and SD
Old Jun 1, 2012 | 11:40 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Will a superduty pickup windshield fit in an excursion? The guy that does my glass work says his book lists them as different? Anyone know what or why?
thank you.
Old Jun 1, 2012 | 12:55 PM
Monsta's Avatar
Monsta
Sit. Stay.
Maybe the graphics the SD version has up top.
Beyond that, they are the same windshield.
Old Jun 2, 2012 | 01:03 AM
bigzirb's Avatar
bigzirb
Per the glass guy that just replaced my Ex glass they are the same. The entire windshield frame is the same as they repaired mine with SD takeout parts. The body shop said it was a perfect fit.
Old Jun 2, 2012 | 09:01 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
The only difference that would matter other than the Super Duty logo is the mirror bracket is just a bit lower in the Excursion to clear the overhead console, (which the others clear it also.) I put a Super Duty windshield in my Excursion and had to cut the cover for wires to the mirror.
Old Jun 2, 2012 | 09:09 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Good. I need to repair the upper windshield channel due to rust holes and the current windshield is going to probably come out in pieces.
Old Jun 2, 2012 | 10:45 AM
RCKYMTN-PSD
got a sharp cold knife and a long pipe knife you can get it out in one piece and save yourself the mess. Squirt some water or glass cleaner on the old sealant and it makes your blade slide much easier.
Old Jun 2, 2012 | 02:11 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Last summer I had my glass guy Reseal the windshield because it was leaking And that is when he saw that it was rusted. So I cleaned it up best I could and he put the sealant to it.
What's a pipe knife?
Old Jun 2, 2012 | 05:37 PM
RCKYMTN-PSD
basically a long piece of conduit pipe. (Irwin utility blade because they wont snap)
Or else a "sabre" knife - www amazon.com/Equalizer-Windshield-Urethane-Cutting-Knife/dp/B005HSOUAG
Old Jun 2, 2012 | 08:59 PM
wallz's Avatar
wallz
thank you.
Yep they fit.
I have the one that has SUPER DUTY across the top.
The only thing is the mirror button is higher, so you need to remove and not use the plastic wire cover that runs down to the mirror.
The other thing is even with the mirror adjusted full down you still get the roof console showing slightly in the mirror.
Old Jun 2, 2012 | 09:12 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Thanks for the heads up wallz
5 on a side
Mar 12, 2019 07:56 AM
aortizexcursion
May 9, 2010 06:22 PM
HKusp
33
Mar 19, 2010 08:59 PM
kengarchow
Apr 8, 2008 02:46 PM
cgl
Jul 3, 2007 05:38 AM
