Although I did not run a shroud on my truck I did make sure all the air coming through the grille was going through the radiator by blocking the top, sides, and bottom. Some things you can to that might help are a shroud, larger fan (more cfm flow), and block areas where air might be going around the radiator instead of through it.
I concur whole heartedly. Ramming as much air as possible through the radiator will certainly help.
I am having the same issue. Running a 360 MOPAR in a '53 panel.
Stock radiator with a full shroud and 3600 cfm fan. Fan relay is set to kick fan on at 180*. Truck wants to run at 205* to 210* and will spit small amount of coolant when I turn it off. I am going to add a overflow tank this week.
Block and radiator have been flushed. New water pump.
Also going to add back the upper and lower radiator seals.
I still have the 7 lb cap. Could I go to a 14-16 lb cap or is that too much? Would that help cool me down a little? Would like to run a 190 ish.
You can easily run a 15 lb cap on the Dodge radiator. That won't make it run cooler but it will probably eliminate the coolant spitting. Make sure you aren't running a 195 degree thermostat. The top and bottom seals help a lot.
I installed a new rad for a 79 f150, it was in front of a 360 motor. I haven't run it yet so I wont know how it is going to work but I can't forsee any problems.
Thanks Bob. Thinking I'll have to ditch the original radiator and go to newer cross flow.
Tried the purple ice and a 160* thermostat with no change. Still waiting on the upper and lower seals and over flow tank, but I doubt they'll make the difference.
I am kinda surprised. I've run a lot of SBC's behind flathead Ford radiators over the years with no issues.
I may still pull the Ford radiator and have it rodded and boiled...
