Erratic Timing
Old May 30, 2012 | 05:53 PM
colescoconutz's Avatar
colescoconutz
Erratic Timing
You have to feather the throttle to start the truck which isnt good then once it finally does start the timing bounces around from around 8* to 13*. Its never consistent. I overheated the truck really bad a few months back (temp sensor doesnt work..) and ever since then i have had nothing but major problems. I wasnt getting any spark initially and the coil was fairly new and seeing as how i had a surging issue at the time i went ahead and changed the ICM for giggles.
Old May 30, 2012 | 06:59 PM
Fungus232's Avatar
Fungus232
Distributor worn out maybe?
Old May 31, 2012 | 07:47 AM
rla2005's Avatar
rla2005
If it is doing this with the SPOUT out, assuming it is, I would lean towards a worn/stretched timing chain.
Old May 31, 2012 | 09:44 AM
colescoconutz
yea rla2005 thats a good call. Thats exactly the next thing im gonna check out. Appreciate it.
Old May 31, 2012 | 09:45 AM
colescoconutz
Whats this SPOUT you're talking about?
Old May 31, 2012 | 10:01 AM
andym's Avatar
andym
The SPOUT is a small grey plug in the wiring to the distributor that disables computer control of the timing. If the plug is in place, the timing will jump around erratically. Looking at the timing with the plug installed is a waste of time. You have to remove the SPOUT to get any meaningful timing information.
Old May 31, 2012 | 11:23 AM
rla2005's Avatar
rla2005
As Andy indicated above it's the plug that enables the computer to control the timing. With the SPOUT connected the timing will vary. If you have set the base timing to ~10* with the SPOUT in then you have severely retarded the base timing. Pull the SPOUT then set the base timing, then re-install the SPOUT.
Your SPOUT connector may look something like the plug on the distributor connector below:
courtesy of oldfuelinjection.com
Or like this:
Old May 31, 2012 | 04:34 PM
colescoconutz
Ok I see the SPOUT that we're talking about. Mine looks like the 2nd pic. I have never touched this plug at all ever...right now there appears to be a resistor plugged into it. I have no idea where Im suppose to plug it back into once i set the base timing.
Old May 31, 2012 | 04:48 PM
Fungus232's Avatar
Fungus232
Pull the grey plug out, set timing, put grey plug back in.
Old May 31, 2012 | 05:02 PM
colescoconutz
Copy that, ok so after I set the timing with it unplugged and everything plugged back in the engine surges hard. I havent pulled the codes yet. Its also ticking pretty bad up top somewhere. The engine was actually surging hard before I could even plug the SPOUT back in.
Old May 31, 2012 | 05:37 PM
colescoconutz
KOEO: 11
CM: 14, 96
On the code 96 I have no front tank installed on the truck, it that helps....
Old May 31, 2012 | 06:26 PM
andym's Avatar
andym
What did you set the timing to?
Old May 31, 2012 | 06:57 PM
colescoconutz
around 10-11*
Old May 31, 2012 | 10:19 PM
Lead Head's Avatar
Lead Head
14: Profile Ignition Pickup Circuit Failure
96: Fuel Pump Circuit Open-Battery To PCM (Others)
96 would be from no first tank.
14 is where you issue lies. I'm thinking either bad TFI module (the module on the distributor), or the pickup inside the distributor itself is bad.
Old May 31, 2012 | 10:29 PM
rla2005's Avatar
rla2005
KOEO: 11
CM: 14, 96
DCT 14: Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall.
As mentioned before, you probably have a bad PIP aka stator inside the distributor.
Info on stator: Fuel Injection Technical Library » Stator (RPM)
410F-100
Apr 15, 2018 08:23 AM
tx64f100tx
15
Aug 28, 2007 09:35 AM
79Ranger302
Jul 25, 2005 10:01 AM
mattmatt77
Sep 14, 2004 07:58 PM
CO_87Bronco
1978 - 1996 Big Bronco
Jun 17, 2003 08:36 PM
